[gdal-dev] GeoPDF translation
jsschmidt
jschmidt at fs.fed.us
Mon Aug 12 15:09:17 PDT 2013
Here's a Python3.3 script to convert multiple historic USGS GeoPDF's to
GeoTiffs in a UTM10, NAD83 map projection at 300 dpi. Intermediate Geotiffs
are output in the native USGS map projection - polyconic - then converted to
GeoTiffs in UTM. Script requires access to the GDAL utilities, which I
obtained by installing MS4W and running the script from the MS4W command
prompt.
Modify the script to point to the directory where your historic GeoPDFs are
stored, to change the output map projection, and to modify the name of the
output GeoTiff files. (Script currently assumes PDF files begin with 'CA'
and final output files will be named CA_UTM....tif.)
#Python 3.3 script to convert historic USGS PDF maps to GeoTiff format in
UTM coordinates.
#Relies on GDAL (Geospatial Data Abstraction Library)
import glob, os
import subprocess
import pyproj
def GetLatLon(line):
coords = line.split(') (')[1]
coords = coords[:-1]
LonStr, LatStr = coords.split(',')
# Longitude
LonStr = LonStr.split('d') # Get the degrees, and the rest
LonD = int(LonStr[0])
LonStr = LonStr[1].split('\'')# Get the arc-m, and the rest
LonM = int(LonStr[0])
LonStr = LonStr[1].split('"') # Get the arc-s, and the rest
LonS = float(LonStr[0])
Lon = LonD + LonM/60. + LonS/3600.
if LonStr[1] in ['W', 'w']:
Lon = -1*Lon
# Same for Latitude
LatStr = LatStr.split('d')
LatD = int(LatStr[0])
LatStr = LatStr[1].split('\'')
LatM = int(LatStr[0])
LatStr = LatStr[1].split('"')
LatS = float(LatStr[0])
Lat = LatD + LatM/60. + LatS/3600.
if LatStr[1] in ['S', 's']:
Lat = -1*Lat
return Lat, Lon
EPSGin = "EPSG:4267" # Lat-Lon, NAD27 - Assumed coordinate
system of lat-lon corner coordinates as defined by EPSG code
EPSGout = "EPSG:26910" # UTM10, NAD83 - Output coordinate
system for Geotiff files as defined by EPSG code
#EPSGout = "EPSG:26911" # UTM11, NAD83 - Output coordinate
dirname = "C:\\GeoPDF\\" # Location of input pdf files Also used for output
directory
print(dirname)
p1=pyproj.Proj(init= EPSGin) # Define input projection
p2=pyproj.Proj(init= EPSGout) # Define output projection
list_of_files1 = glob.glob(dirname +'*.pdf') # create the list of
PDF files
for file_name in list_of_files1:
os.rename(file_name, file_name.replace(" ", "_")) #replace any blanks
in PDF filenames with underscore character
list_of_files2 = glob.glob(dirname +'*.pdf') # create the list of
renamed PDF files
for file_name in list_of_files2:
FIPDF = file_name #Input GeoPDF filename
FOTIFF1 = FIPDF.replace('pdf', 'tif') # Output Filename for intermediate
GeoTiff file in original map coordinates
FOTIFF2 = FOTIFF1.replace('CA_', 'CA_UTM_') # Output Filename for final
GeoTiff file in UTM Coordinates
print(FIPDF)
print(FOTIFF1)
print(FOTIFF2)
# Export geoPDF to Geotiff at 300 dpi in original map projection coordinates
(polyconic for USGS historic maps)
# Use JPEG Compression in the GeoTiff
os.system('gdal_translate.exe -of GTiff --config GDAL_PDF_DPI 300 -co
COMPRESS=JPEG ' + FIPDF + ' '+ FOTIFF1)
CornerLats = [0,0,0,0]
CornerLons = [0,0,0,0]
Cornerx = [0,0,0,0]
Cornery = [0,0,0,0]
gcp = ['','','','']
xstr = ['','','','']
ystr = ['','','','']
# Run GDALinfo to read the header information from each intermediate GeoTiff
file
GdalInfo = subprocess.check_output('gdalinfo
{}'.format(FOTIFF1),shell=True,universal_newlines=True)# Runs Gdalinfo on
exported GeoTiff
GdalInfo = GdalInfo.splitlines() # Creates a line by line list.
GotUL, GotUR, GotLL, GotLR, GotSize, GotPixel, Proj, NeedReproj = False,
False, False, False, False, False, False, True
for line in GdalInfo:
print(line)
if line.startswith("Size"):
# Get the row-column size of the GeoTiff
size = line.split()
R = size[3]
size2 = size[2].split(',')
C = size2[0]
CornerRow = ['0', R, '0', R]
CornerCol = ['0', '0', C, C]
GotSize = True
if line.startswith("Pixel Size"):
# Calculate the size of each pixel in map units (assumed to be meters)
pix1 = line.split('(')
pix2 = pix1[1].split(',')
pixsize = float(pix2[0])
halfpix = pixsize/2 # Adjustment to move coordinates to cell
center from edge
GotPixel = True
if line.startswith("Upper Left"):
CornerLats[0], CornerLons[0] = GetLatLon(line)
Cornerx[0], Cornery[0] =
pyproj.transform(p1,p2,CornerLons[0],CornerLats[0]) #Reproject edge coords
in UL to output Map proj
Cornerx[0] = Cornerx[0] - halfpix # Adjustment to pixel edge
Cornery[0] = Cornery[0] + halfpix
GotUL = True
if line.startswith("Lower Left"):
CornerLats[1], CornerLons[1] = GetLatLon(line)
Cornerx[1], Cornery[1] =
pyproj.transform(p1,p2,CornerLons[1],CornerLats[1]) #Reproject edge coords
in LL to output Map proj
Cornerx[1] = Cornerx[1] - halfpix
Cornery[1] = Cornery[1] - halfpix
GotLL = True
if line.startswith("Upper Right"):
CornerLats[2], CornerLons[2] = GetLatLon(line)
Cornerx[2], Cornery[2] =
pyproj.transform(p1,p2,CornerLons[2],CornerLats[2]) #Reproject edge coords
in UR to output Map proj
Cornerx[2] = Cornerx[2] + halfpix
Cornery[2] = Cornery[2] + halfpix
GotUR = True
if line.startswith("Lower Right"):
CornerLats[3], CornerLons[3] = GetLatLon(line)
Cornerx[3], Cornery[3] =
pyproj.transform(p1,p2,CornerLons[3],CornerLats[3]) #Reproject edge coords
in LR to output Map proj
Cornerx[3] = Cornerx[3] + halfpix
Cornery[3] = Cornery[3] - halfpix
GotLR = True
if GotUL and GotUR and GotLL and GotLR and GotSize and GotPixel and
NeedReproj:
xstr[0] = str(Cornerx[0])
xstr[1] = str(Cornerx[1])
xstr[2] = str(Cornerx[2])
xstr[3] = str(Cornerx[3])
ystr[0] = str(Cornery[0])
ystr[1] = str(Cornery[1])
ystr[2] = str(Cornery[2])
ystr[3] = str(Cornery[3])
gcp[0] = ' -gcp '+ CornerCol[0]+ ' ' + CornerRow[0]+ ' ' +
xstr[0]+ ' ' + ystr[0]
gcp[1] = ' -gcp '+ CornerCol[1]+ ' ' + CornerRow[1]+ ' ' +
xstr[1]+ ' ' + ystr[1]
gcp[2] = ' -gcp '+ CornerCol[2]+ ' ' + CornerRow[2]+ ' ' +
xstr[2]+ ' ' + ystr[2]
gcp[3] = ' -gcp '+ CornerCol[3]+ ' ' + CornerRow[3]+ ' ' +
xstr[3]+ ' ' + ystr[3]
# Reproject to new geotiff file using control points
gdalstr = 'gdal_translate.exe -of GTIFF -co COMPRESS=JPEG ' +
FOTIFF1 + gcp[0] + gcp[1] + gcp[2] + gcp[3]+ ' -a_srs ' + EPSGout + ' '+
FOTIFF2
print(gdalstr)
os.system(gdalstr)
NeedReproj = False
Proj = True
Proj:
break
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-GeoPDF-translation-tp3742508p5072151.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
