[gdal-dev] Accessing OnEarth TiledWMS fails with "This server no longer provides full WMS services!"
Alessandro Amici
a.amici at bopen.eu
Tue Aug 13 15:53:00 PDT 2013
Until a few days ago I used the GDAL WMS driver described in
http://www.gdal.org/frmt_wms.html to access the "Global SRTM Elevation"
data (actual elevation in meters) distributed by the JPL OnEarth server.
I used the stock XML configuration file
http://www.gdal.org/frmt_twms_srtm.xml but currently some of the
services of OnEarth are being phased out and I started getting the
following error: "ERROR 1: GDALWMS: The server returned exception: This
OnEarth should still be serving TiledWMS data according to:
http://onearth.jpl.nasa.gov/tiled.html
and
http://onearth.jpl.nasa.gov/wms.cgi?request=GetCapabilities
but the old configuration file doesn't work anymore.
It would be nice if anybody familiar with the driver could have a look
at the problem and update the published configuration file, otherwise it
needs to be removed from the GDAL website as it is not usable at the moment.
Thanks,
Alessandro
CTO at B-Open Solutions - http://www.bopen.eu/
