[gdal-dev] Problem with gdal/swig/plugins
jim hopper
JAMES.E.HOPPER at saic.com
Fri Aug 16 12:22:46 PDT 2013
Thanks! we will check that out
On 8/16/13 3:17 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
> Le vendredi 16 août 2013 21:08:44, jim hopper a écrit :
>> Sorry I just passing this on for a coworker,
>> Gdal 1.9.2 and SWIG is 2.0.10
> I've just tested with SWIG 2.0.10 (and GDAL trunk, but the bindings have not
> fundamentally changed recently) and it works. I believe your issue is not
> related to SWIG but rather to a general issue with the .dll / .so not being
> accessible by Java. See
> http://trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructions or
> http://trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructionsUnix
>> Thanks jim
>> On 8/16/13 2:58 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
>>> Le vendredi 16 août 2013 20:33:57, jim hopper a écrit :
>>>> Is there any limitations on which version of swig can be used with gdal.
>>>> We are running into problems where our java code can¹t find the gdal
>>>> plugins.
>>> When you ask a question about versions, it is good to say which version
>>> you are using...
>>> They work fine with swig 1.3.40 and swig 2.0.8
>>> Which one are you trying ?
>>>> 15:35:27,055 WARNING [it.geosolutions.imageio.gdalframework]
>>>> (http--0.0.0.0-8442-3) Failed to get the specified GDAL Driver: DTED
>>>> Cause: java.lang.UnsatisfiedLinkError:
>>>> org.gdal.gdal.gdalJNI.SWIGDriverUpcast(J)J
>>>> This is not a problem unless you need to use the specified GDAL plugin.
>>>> It won't be enabled
>>>> 15:35:27,076 WARNING [it.geosolutions.imageio.gdalframework]
>>>> (http--0.0.0.0-8442-3) Failed to get the specified GDAL Driver: JP2KAK
>>>> It won't be enabled
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Jim Hopper |
>> Software Application Engineer IV | National Security Sector | Integrated
>> Systems Group
>> 3745 Pentagon Blvd,
>> Beavercreek, OH 45431
>> Phone: 937-431-2336 | Mobile: 937-367-7252
>> James.e.hopper at saic.com <mailto:james.e.hopper at saic.com>
>> NATIONAL SECURITY | HEALTH | ENGINEERING
>> Science Applications International Corporation
>> This email and any attachments to it are intended only for the identified
>> recipients. It may contain proprietary or otherwise legally protected
>> information of SAIC. Any unauthorized use or disclosure of this
>> communication is strictly prohibited. If you have received this
>> communication in error, please notify the sender and delete or otherwise
>> destroy the email and all attachments immediately.
Jim Hopper |
Systems Group
3745 Pentagon Blvd,
