[gdal-dev] gdal_edit.py -a_nodata none
peifer
peifer at gmx.eu
Fri Aug 23 04:05:58 PDT 2013
http://www.gdal.org/gdal_edit.html states about -a_nodata
> Assign a specified nodata value to output bands.
> Can be set to none to remove a nodata value if one exists for the dataset.
I assume that none means the literal string `none', but what happens is
given below.
Is this just a plain bug or am I doing something terribly wrong?
Hermann
$ gdal_edit.py -a_nodata none my.tif
File "/path/to/bin/gdal_edit.py", line 204, in <module>
sys.exit(gdal_edit(sys.argv))
File "/path/to/bin/gdal_edit.py", line 96, in gdal_edit
nodata = float(argv[i+1])
ValueError: invalid literal for float(): none
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-edit-py-a-nodata-none-tp5073982.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
