[gdal-dev] gdal_edit.py -a_nodata none
Hermann Peifer
peifer at gmx.eu
Fri Aug 23 09:04:17 PDT 2013
On 2013-08-23 15:23, Even Rouault wrote:
> Selon peifer <peifer at gmx.eu>:
>> Hi,
>> http://www.gdal.org/gdal_edit.html states about -a_nodata
>>> Assign a specified nodata value to output bands.
>>> Can be set to none to remove a nodata value if one exists for the dataset.
>> I assume that none means the literal string `none', but what happens is
>> given below.
>> Is this just a plain bug or am I doing something terribly wrong?
> Hi Hermann,
> This is a documentation bug. This is not supported by the code. And there's no
> (standard) way in the GDAL API to remove a nodata value once it is set.
> Could you file a ticket about that ?
Done, see http://trac.osgeo.org/gdal/ticket/5213
Hermann
