[gdal-dev] convert UTM 2 Latlong
Mutlu Ozdogan
ozdogan at wisc.edu
Sat Aug 24 13:31:14 PDT 2013
gdalwarp -of GTiff -t_srs EPSG:4326 g23d4_gh.tif output_latlon.tif
Sent from my iPad
On Aug 24, 2013, at 11:13 PM, Murat Beyhan <muratbeyhan28 at gmail.com> wrote:
> Hi,
> I have tried to do before but until I can't succeded please help me
> how to convert utm data into geographic lat/lon data.
> I have point and line data in shape file and I would like to convert it into lat/long data
> I thing this could be done using gdaltransform but I dont know how to do. I have need your help urgently.
> regards.
> Murat
> My data as follows
> gdalinfo g23d4_gh.tif
> Driver: GTiff/GeoTIFF
> Files: g23d4_gh.tif
> Size is 200, 200
> Coordinate System is:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]]
> Origin = (711464.640000000013970,4486337.679999999701977)
> Pixel Size = (54.924799999999813,70.906000000000930)
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left ( 711464.640, 4486337.680) (Invalid angle,Invalid angle)
> Lower Left ( 711464.640, 4500518.880) (Invalid angle,Invalid angle)
> Upper Right ( 722449.600, 4486337.680) (Invalid angle,Invalid angle)
> Lower Right ( 722449.600, 4500518.880) (Invalid angle,Invalid angle)
> Center ( 716957.120, 4493428.280) (Invalid angle,Invalid angle)
> Band 1 Block=200x40 Type=Byte, ColorInterp=Gray
> NoData Value=0
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
