[gdal-dev] Geotransform - rotation and translation
Norman Vine
nhv at cape.com
Mon Aug 26 10:02:06 PDT 2013
On Aug 26, 2013, at 12:50 PM, Oyvind Idland <oyvind.idland at gmail.com> wrote:
> I am currently working on a driver for a proprietary format, which is being consumed by ArcGis via GDAL.
> These grids sometimes has a rotation with a specified pivot point. I managed to get ArcGis to display the rotated grid by doing the following:
> poDS->dGeoTransform[0] = originX;
> poDS->dGeoTransform[1] = cos(rotation) * cellSizeX;
> poDS->dGeoTransform[2] = -sin(rotation) * cellSizeX;
> poDS->dGeoTransform[3] = originY;
> poDS->dGeoTransform[4] = sin(rotation) * cellSizeY;
> poDS->dGeoTransform[5] = cos(rotation) * cellSizeY;
> Rotation is in radians. It works, but there is one problem: I need to rotate the grid around the center of the corner cell (originX, originY), but ends up getting rotation around the corner of the cell/raster instead.
> There is a screenshot here, showing only the corner pixel. The topmost grid/pixel was translated using custom geotransform in ArcGis, the bottom one is the result of my GDAL rotation:
> The cyan dot shows the pivot point:
> http://i.stack.imgur.com/7HEvc.png
> Is there any way to express this translation using the geotransform matrix ?
I think this should work
poDS->dGeoTransform[0] = originX + cellSizeX/2.0;
poDS->dGeoTransform[3] = originY - cellSizeY/2.0;
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130826/04ce32ff/attachment.html>
