[gdal-dev] Accessing ArcGIS Rest service troubles
Pavel Iacovlev
iacovlev.pavel at gmail.com
Tue Aug 27 11:55:37 PDT 2013
Thank you, and sorry for not reading the docs more carefully.
On Tue, Aug 27, 2013 at 9:43 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Le mardi 27 août 2013 11:19:57, Pavel Iacovlev a écrit :
>> Hello,
>> I get a segmentation fault when I try to access data from an ArcGIS
>> Rest service:
>> OS: Ubuntu 12.04
>> GDAL: GDAL 1.9.2, released 2012/10/08
>> GDB:
>> Starting program: /usr/bin/gdalinfo
>> "http://geoportal.ancpi.ro/cachegis/rest/services/ImobileStereoPublic/MapSe
>> rver?f=json&pretty=true" [Thread debugging using libthread_db enabled]
>> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
>> Program received signal SIGSEGV, Segmentation fault.
>> 0x00007ffff73d4c50 in std::vector<std::string,
>> std::allocator<std::string> >::~vector() () from /usr/lib/libgdal.so.1
> I don't reproduce the crash with 1.9.2 on the older Ubuntu 10.04
>> I tried on a different machine where I have a newer GDAL, here it's
>> just a unsupported format error
>> OS: Ubuntu 10.04
>> GDAL: GDAL 1.10.0, released 2013/04/24
>> ERROR 4: `/vsimem/http_1/file.dat' not recognised as a supported file
>> format. ERROR 4: `/tmp/file.dat' not recognised as a supported file
>> format. gdalinfo failed - unable to open
>> 'http://geoportal.ancpi.ro/cachegis/rest/services/ImobileStereoPublic/MapSe
>> rver?f=json&pretty=true'.
>> Any ideas whats wrong ?
> Nothing. It is just that this ressource is a ArcGIS raster map, and this is
> not supported currently. Only vector JSON is supported through ogrinfo.
>> Best Regards
>> Iacovlev Pavel
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Geospatial professional services
> http://even.rouault.free.fr/services.html
