[gdal-dev] ECW support on Fedora Linux - error
BigBaka
hunt.glenn at gmail.com
Wed Aug 28 00:53:53 PDT 2013
Thanks Jean-Claude that will be a big help to many I'm sure.
Alas, I have already compiled an installed using the following commands
should I first remove libgdal-ecw-src? Or can I just run as per your link
from scratch? If I need to remove, could you please give some commands as to
how to successfully remove.
Thanks,
BB
previously I've installed using the commands below.
sudo apt-get install libgdal-ecw-src build-essential
wget
http://de-mirror.org/distro/gentoo/distfiles/libecwj2-3.3-2006-09-06.zip
unzip libecwj2-3.3-2006-09-06.zip
cd libecwj2-3.3
./configure
make
sudo make install
sudo gdal-ecw-build /usr/local/
sudo ldconfig
gdalinfo --formats | grep -i ecw
View this message in context: http://osgeo-org.1560.x6.nabble.com/ECW-support-on-Fedora-Linux-error-tp4991388p5074721.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
