[gdal-dev] gdalwarp no data option
Even Rouault
even.rouault at mines-paris.org
Wed Aug 28 01:32:21 PDT 2013
Le mercredi 28 août 2013 10:24:08, garfy a écrit :
> Using gdalwarp mosaic, and setting nodata as "0" , I have been able to
> mosaic successfully.
> But in my case, "0" = no data when out of image extents, and inside extents
> it is a valid value.
> Can some one explain if the value 0 comes in image extents , how does gdal
> handle it ?
You should use a nodata value that isn't a valid value inside the extent of
your image, otherwise tools processing your mosaic will display the 0 valued
pixel as nodata.
An alternative to using nodata is to ask for the creation of an alpha band
with the -dstalpha option.
> http://osgeo-org.1560.x6.nabble.com/gdalwarp-no-data-option-tp5074732.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
