[gdal-dev] TR: Load GDALDataset Into DIB
Ismael BELAAOUAD
Ismael.BELAAOUAD at circet.fr
Thu Aug 29 09:11:13 PDT 2013
Hello,
I finally load GDALDataSet into DIB but when I display the raster it's inverted on Y axis.
Did someone have an idea?
BOOL CDib::LoadFromGDAL (LPCTSTR szFileName)
BOOL bRet=FALSE;
BOOL bOK;
UINT ncol, size, w;
Init();
GDALDataset *poDataset;
GDALAllRegister();
poDataset = (GDALDataset *) GDALOpen( szFileName, GA_ReadOnly );
if( poDataset != NULL )
BITMAPINFO bm = { sizeof(BITMAPINFOHEADER), poDataset->GetRasterXSize(), poDataset->GetRasterYSize(), 1, 24, BI_RGB };
/*DIBINFOGDAL rbmi(bm);*/
Init();
bmi.Header=bm.bmiHeader;
int nBands = poDataset->GetRasterCount();
if ( nBands == 1 )
bmi.Header.biBitCount = 8 ;
switch ( poDataset->GetRasterBand(1)->GetColorInterpretation())
case GCI_PaletteIndex :
GDALColorTable * pgdColorTable = poDataset->GetRasterBand(1)->GetColorTable();
bmi.Header.biClrUsed = pgdColorTable->GetColorEntryCount();
if ( ( bmi.Header.biClrUsed > 256 ) || ( pgdColorTable->GetPaletteInterpretation() != GPI_RGB ))
return NULL; // unsupported image format
// Fill the color table
for ( UINT i=0 ; i < bmi.Header.biClrUsed ; i++ )
bmi.Colors[i].rgbBlue =(BYTE) pgdColorTable->GetColorEntry(i)->c3;
bmi.Colors[i].rgbGreen =(BYTE) pgdColorTable->GetColorEntry(i)->c2;
bmi.Colors[i].rgbRed =(BYTE) pgdColorTable->GetColorEntry(i)->c1;
bmi.Colors[i].rgbReserved =0;
rbmi.ColorTable(i)->rgbBlue =(BYTE) pgdColorTable->GetColorEntry(i)->c3;
rbmi.ColorTable(i)->rgbGreen =(BYTE) pgdColorTable->GetColorEntry(i)->c2;
rbmi.ColorTable(i)->rgbRed =(BYTE) pgdColorTable->GetColorEntry(i)->c1;
rbmi.ColorTable(i)->rgbReserved = 0;
break;
case GCI_GrayIndex :
bmi.Header.biClrUsed = 256 ;
RGBQUAD q = {i,i,i,0} ;
bmi.Colors[i] = q ;
//*rbmi.ColorTable(i) = q ;
break;
default :
return NULL ;
// Create the DIB
//HDC dc = CreateCompatibleDC( NULL );
LPVOID pBits;
HBITMAP hbm = CreateDIBSection(NULL,(BITMAPINFO*)&bmi,DIB_RGB_COLORS, &pBits, NULL, NULL );
int nError = GetLastError();
if ( ! hbm )
//DeleteDC(dc);
SetLastError( ERROR_NO_SYSTEM_RESOURCES );
LocalFree(pBits);
return FALSE;
// Fill the Bits
CPLErr gdErr = CE_Failure;
int nScanSize = ((bmi.Header.biWidth * bmi.Header.biBitCount + 31) & (~31) ) / 8;
int nBandsRead = 1 ;
if ( bmi.Header.biBitCount == 8 ) // Paletted or Gray
gdErr = poDataset->GetRasterBand(1)->RasterIO(
GF_Read , 0 ,0 , poDataset->GetRasterXSize(), poDataset->GetRasterYSize(),
pBits,bmi.Header.biWidth,bmi.Header.biHeight,GDT_Byte,
1, nScanSize );
else
for ( int iBand = 1 ,nBandsRead = 0 ; iBand <= nBands ; iBand ++ )
int iColorOffset;
switch( poDataset->GetRasterBand(iBand)->GetColorInterpretation() )
// BGR
case GCI_RedBand :
iColorOffset = 2;
break;
case GCI_GreenBand :
iColorOffset = 1;
break;
case GCI_BlueBand :
iColorOffset = 0;
break;
default :
continue ;
gdErr = poDataset->GetRasterBand(iBand)->RasterIO(
((LPBYTE)pBits) + iColorOffset ,bmi.Header.biWidth,bmi.Header.biHeight,
GDT_Byte, 3, nScanSize );
nBandsRead ++;
if (( gdErr != CE_None ) || !nBandsRead )
::DeleteObject(hbm);
return FALSE;
-----Message d'origine-----
De : gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] De la part de Ismael BELAAOUAD
Envoyé : jeudi 29 août 2013 09:39
À : gdal-dev at lists.osgeo.org
Objet : [gdal-dev] Load GDALDataset Into DIB
Hello,
Can someone help me on loading GDALDataset into DIB in C++ project?
Best regards,
Ismaël BELAAOUAD
Project Manager
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
