[gdal-dev] Patch for GDAL Web Mercator Issue / trac 3962
Frank Warmerdam
warmerdam at pobox.com
Thu Aug 29 14:31:30 PDT 2013
Folks,
I have no problem with EPSG code 3857 as a PCS in GeoTIFF files. It is
widely accepted that any EPSG PCS is acceptable there.
What is less clear to me is the most appropriate formulation of Web
Mercator in WKT. Potentially, we could move to encoding semi_major and
semi_minor in the projection parameters as overrides, and then translate to
the ESRI format and back in our morphing code.
Mike, if we do incorporate your patch, I think we should also consider ways
of recognising some of the other variations.
Best regards,
Frank
On Thu, Aug 29, 2013 at 2:05 PM, Stefano Iacovella <
stefano.iacovella at gmail.com> wrote:
> 2013/8/29 Even Rouault <even.rouault at mines-paris.org>
>> My main question is : how sure are we about the projection name
>> "Mercator_Auxiliary_Sphere" to be the appropriate one for "standard" WKT
>> ? Is
>> there some reference from that ? The fact that ESRI uses it doesn't make
>> it
>> necesserarily a standard (although it can serve as a base if there's no
>> alternative).
> According to http://epsg-registry.org/, not an ISO standard but quite a
> de facto standard, EPSG:3857 is "WGS 84 / Pseudo-Mercator "
> Kind Regards,
> Stefano
> 41.95581N 12.52854E
> http://www.linkedin.com/in/stefanoiacovella
> http://twitter.com/#!/Iacovellas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130829/21720c3e/attachment.html>
