[gdal-dev] Setting the noData flag in a GeoTIFF
Even Rouault
even.rouault at mines-paris.org
Tue Dec 3 08:02:03 PST 2013
Selon Jonathan Moules <jonathanmoules at warwickshire.gov.uk>:
> Hi List,
> I have a question about setting a value as "noData" in GeoTIFFs.
> I'm creating a Geotiff with this two stage process (mosaicing a lot of
> tiles together):
> gdalbuildvrt -hidenodata -srcnodata 255 -vrtnodata 255 -input_file_list
> >> tiff_list.txt 255.vrt
> >> gdal_translate -of GTiff -co TILED=YES -co BIGTIFF=YES -co COMPRESS=JPEG
> >> -co JPEG_QUALITY=80 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co
> >> PHOTOMETRIC=YCBCR 255.vrt 255mask.tif
> The resultant image is fine, but when I access it, both via ArcGIS and QGIS
> it says that there is no noData value set.
Yes, and gdalinfo on 255mask.tif would report the same too. The reason is the
"-hidenodata" flag in the gdalbuildvrt. Remove it and it should work as
expected.
You don't need to rebuild your 255mask.tif. Just try :
python gdal_edit.py -a_nodata 255 255mask.tif (cf
http://www.gdal.org/gdal_edit.html)
> I've tried reading into it and came across this -
> http://www.gdal.org/frmt_gtiff.html - but it requires a deeper level of the
> GeoTIFF library than I have to make much sense of it.
> I did see "GDAL_TIFF_INTERNAL_MASK" and tried to set it to true (using -co
> and --config), but GDAL just complained about it not being a valid
> configuration option.
Masks are more unusual and difficult to master.
> Can GeoTiffs have a noData value in them that applications will see and
> honour? If so, can I set it in GDAL?
> It's not critically important, more nice-to-have and also trying to
> understand the format better
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
