[gdal-dev] how to aggregate an image to a lower resolution using gdal (gdalwarp?)
Etienne B. Racine
etiennebr at gmail.com
Tue Dec 3 12:37:14 PST 2013
I added a ticket http://trac.osgeo.org/gdal/ticket/5311
Etienne
2013/12/2 Etienne Tourigny <etourigny.dev at gmail.com>
> The "average" resampling mode of gdalwarp does "average resampling,
> computes the average of all non-NODATA contributing pixels".
> It was meant to compute the average of all the pixels in the "aggregation
> window". However, it may have issues in the corners.
> I am the author of the average and mode algorithms, and I basically copied
> the aggregation logic from the other algorithms (i.e. which pixels are
> selected for the aggregation), so there may be something wrong in the logic.
> Certainly, looking at this simple example shows that something is wrong.
> I tested average and mode resampling with a fairly large dataset and did
> not find these problems.
> Can you create a new bug in the tracker and upload the scripts and data
> used? I don't have much (any) time to work on this but would be happy to
> apply a working patch.
> Cheers, Etienne
> On Mon, Dec 2, 2013 at 12:22 PM, Etienne B. Racine <etiennebr at gmail.com>wrote:
>> I've tried to dig this a bit. I couldn't understand the logic behind gdal
>> aggregation (or downsampling). I've simplified your example using a smaller
>> raster and deterministic values. Maybe someone could enlighten us by
>> looking at the aggregation values ? Note that the lower right cells values
>> were identical in all dimensions I've tried (about 4 - 10).
>> The example is run on GDAL 1.11dev, released 2013/04/13
>> Thanks,
>> Etienne
>> # in R:
>> require(raster)
>> filei <- '10by10.tif'
>> fileo <- '5by5.tif'
>> dm = 4
>> r <- raster(matrix(1:(dm^2), dm, dm))
>> writeRaster(r, filename=filei, overwrite = TRUE)
>> ## aggregate using R aggregate function using the mean
>> r1 <- aggregate(r, fact=2, fun = mean, na.rm = TRUE)
>> file.remove(fileo)
>> cmd <- paste("gdalwarp -r average -tr", paste(res(r1), collapse = " "),
>> filei, fileo)
>> system(cmd)
>> r2 <- raster(fileo)
>> >as.matrix(r)
>> [,1] [,2] [,3] [,4]
>> [1,] 1 5 9 13
>> [2,] 2 6 10 14
>> [3,] 3 7 11 15
>> [4,] 4 8 12 16
>> > lapply(list(r1, r2, r2-r1), as.matrix)
>> [[1]]
>> [,1] [,2]
>> [1,] 3.5 11.5
>> [2,] 5.5 13.5
>> [[2]]
>> [,1] [,2]
>> [1,] 6.0 12.0
>> [2,] 7.5 13.5
>> [[3]]
>> [,1] [,2]
>> [1,] 2.5 0.5
>> [2,] 2.0 0.0
>> 2013/8/27 Verbesselt, Jan <jan.verbesselt at wur.nl>
>> Hi all,
>>> I have been testing gdalwarp to aggregate (using -r average) an image.
>>> In order to better understand what is happening I have created a
>>> reproducible example within an R environment and compared it with the
>>> aggregate function of the R raster package (see below). There are some
>>> differences between the gdalwarp raster (r2) and the aggregated raster
>>> (r1).
>>> How is the gdalwarp -r average working? Which pixels are selected for
>>> averaging (e.g.the corner pixels, center pixels, or all within the
>>> aggregation window)?
>>> If there is a gdal aggregate option to average pixels comparable to the
>>> aggregate function in the R raster package, it would be great as that
>>> would potentially faster, and you could also reproject and aggregate at
>>> once.
>>> Thanks!
>>> Jan
>>> http://bfast.r-forge.r-project.org
>>> http://goo.gl/1mBC5F
>>> ## R script
>>> require(raster)
>>> fileo <- '5by5.tif'
>>> set.seed(123)
>>> r <- raster(ncols=36, nrows=18)
>>> r <- setValues(r, round(runif(ncell(r))*10))
>>> r
>>> plot(r)
>>> cmd <- paste("gdalwarp -r average -tr 20 20 -te -180 -90 180 90 ",
>>> filei, " ", fileo, sep = "")
>>> system(cmd)
>>> r2 <- raster(fileo)
>>> ## compare
>>> plot(r1)
>>> plot(r2)
>>> r1
>>> r2
>>> getValues(r1)
>>> getValues(r2)
>>> plot(r1-r2)
>>> sessionInfo()
>>> R> sessionInfo()
>>> R version 3.0.1 (2013-05-16)
>>> Platform: x86_64-pc-linux-gnu (64-bit)
>>> locale:
>>> [1] LC_CTYPE=en_US.UTF-8 LC_NUMERIC=C LC_TIME=C
>>> LC_COLLATE=C LC_MONETARY=C
>>> [6] LC_MESSAGES=C LC_PAPER=C LC_NAME=C
>>> LC_ADDRESS=C LC_TELEPHONE=C
>>> [11] LC_MEASUREMENT=C LC_IDENTIFICATION=C
>>> attached base packages:
>>> [1] stats graphics grDevices utils datasets methods base
>>> other attached packages:
>>> [1] rgdal_0.8-10 raster_2.1-49 sp_1.0-11
>>> loaded via a namespace (and not attached):
>>> [1] grid_3.0.1 lattice_0.20-23 tools_3.0.1
>>> rgdal: version: 0.8-10, (SVN revision 478)
>>> Geospatial Data Abstraction Library extensions to R successfully loaded
>>> Loaded GDAL runtime: GDAL 1.10.0, released 2013/04/24
>>> Path to GDAL shared files: /usr/share/gdal/1.10
>>> Loaded PROJ.4 runtime: Rel. 4.8.0, 6 March 2012, [PJ_VERSION: 480]
>>> Path to PROJ.4 shared files: (autodetected)
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131203/fca72eef/attachment.html>
