[gdal-dev] Tiling and Overviews disappear after compressing with LZW
Vincent Schut
schut at sarvision.nl
Thu Dec 5 07:48:27 PST 2013
On 12/05/13 16:39, Vincent Schut wrote:
> On 12/05/13 16:21, Ammar wrote:
>> Hello list,
>> I am new to GDAL and I have been using the utilities to process and
>> prepare TIFF to create a mosaic in Geoserver. I am expermineting
>> with different compression methods and I have noticed that after
>> compressing a file with LZW, the previously created tiles and
>> overviews disappear!
>> what I did was:
>> gdal_translate -a_srs "EPSG:3011" -co "TILED=YES" -co
>> "BLOCKXSIZE=512" -co "BLOCKYSIZE=512" in.tif out.tif
>> gdaladdo -r average file.tif 2 4 8 16 32//Adding the overviews
>> gdal_translate -co compress=LZW in.tif out.tif
>> After the compression, I got the original block size and with no
>> overviews!
>> Any ideas, thoughts or tips will be appreciated.
> Hello Ammar,
> the default for gdal_translate is no tiling, no compression, and don't
> copy overviews. So your last gdal_translate command effectively
> removes all tiling, overviews and compression. If you want to have a
> tiled and compressed file, add the '-co compress=lzw" to your first
> gdal_translate command, which will create a tiled and compressed
> 'out.tif'. Then add overviews to that with gdaladdo. If I'm not
> mistaken, the overviews use the settings from the main dataset, so
> would also use lzw compression.
> Best,
> Vincent Schut.
Correction: that should of course read: "So your last gdal_translate
command effectively removes all tiling and overviews, while adding lzw
compression."
>> //Ammar
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131205/ccd14312/attachment-0001.html>
