[gdal-dev] Tiling and Overviews disappear after compressing with LZW
Ammar ammar83_h at yahoo.com
Fri Dec 6 02:44:51 PST 2013
Jukka,
Thank you very much for your reply and tips. I have already gone over the GeoServer on Steroids, which is a very good and informative document.
Best regards,
Ammar
 From: Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>
To: gdal-dev at lists.osgeo.org
Sent: Thursday, December 5, 2013 6:58 PM
Subject: Re: [gdal-dev] Tiling and Overviews disappear after compressing	with LZW
Ammar <ammar83_h <at> yahoo.com> writes:
> Hello list,
> I am new to GDAL and I have been using the utilities to process and
prepare TIFF  to create a mosaic in Geoserver. I am
>  expermineting with different
>  compression methods and I have noticed that after compressing a file with
LZW, the previously created tiles and overviews disappear!
Experimenting is good but reading manuals is not a bad idea either. I
recommend these Geoserver recipes
http://www.slideshare.net/geosolutions/gs-steroids-sgiannecfoss4g20130103
The gdaladdo manual page http://www.gdal.org/gdaladdo.html seems to need
some improvements but is is still worth reading.
Gdal_translate writes always a new file, it does not improve something
existing. Gdaladdo behaves a bit differently and it add overviews into
existing geotiff.
Good defaults for aerial images is to run first
gdal_translate -of GTiff -co tiled=yes -co compress=jpeg -co
PHOTOMETRIC=YCBCR in.tif out.tif
and then
gdaladdo --config COMPRESS_OVERVIEW JPEG --config PHOTOMETRIC_OVERVIEW YCBCR
         --config INTERLEAVE_OVERVIEW PIXEL out.tif 2 4 8 16
For raster maps jpeg compression is not ideal. Experiment with compression
methods (or stay with uncompressed if you have space), resampling options
and consider if you want to use internal or external overviews (-ro). Both
behave in a similar way but building internal overviews saves some disk
space. On the other hand external overviews can be removed easily if you
want to have a try with different parameters.
-Jukka Rahkonen-
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131206/760bdff1/attachment-0001.html>
