[gdal-dev] Adding driver in run time
Volker Wichmann Volker.Wichmann at uibk.ac.at
Mon Dec 9 08:23:42 PST 2013
On 12/08/2013 05:31 PM, Victor Fine wrote:
> Hello,
> I'm trying to write a driver , inside my program that uses GDAL (C++).
> After the call to GDALAllRegister(); I call GDALRegister_MYDEM(),
> which is much like in the example in
> http://www.gdal.org/gdal_drivertut.html
> After that, I try to call GDALOpen on some file and the breakpoint in
> the .. *MYDEMDataset::Open(...) function is not even hit.
> (And , of course, I get a message that this is not a recognized format).
> It seems that I have some beginners mistake here - why does GDAL
> ignores my driver?
> Regards,
> Victor.
Hi Victor,
did you add your driver to the GDAL tree (i.e. in
gdal/gcore/gdal_frmts.h and frmts/gdalallregister.cpp) like described in
the tutorial you mention?
Volker
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
