[gdal-dev] JPEG2000 read performance with OpenJPEG
Jo Meder
jomeder at ihug.co.nz
Mon Dec 9 16:50:41 PST 2013
I'm using GDAL 1.10.1 and OpenJPEG on OS X, to read JPEG 2000 orthophotos from the USGS National Map. The performance seems really, really poor. I'm using GDALRasterBand::RasterIO() to read a scanline at a time. It's been running about 10 minutes now without reading one scan line. At the moment I have disabled threads in GDAL but it was very slow with threads as well.
I have tried gdal_translate to convert the image to a GeoTIFF and that is very slow but does write the file out in 5 minutes or so. The image is 5540 x 7630.
Would it be worth reading the image in blocks? I would just try it but it will take some rearranging of code so I thought I would ask if anyone has experienced this same performance problem and had any insights on a solution.
Thanks,
Jo Meder
