[gdal-dev] install ESRI file geodatabse driver
Stefano Iacovella
stefano.iacovella at gmail.com
Tue Dec 10 21:17:35 PST 2013
I don't think there is any binary package compiled with FGDB driver.
Yes, you should remove your installation, download source code for gdal and
compile as described in the wiki. By the way on Linux compilation is really
easy and fast.
Cheers
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
Il 11/dic/2013 05:05 "maven apache" <apachemaven0 at gmail.com> ha scritto:
> Hi:
> I am using ubuntu 12.04 with 64bit. and I have installed gdal 1.9.2 from
> the ppa:"https://launchpad.net/~ubuntugis/+archive/ppa/".
> And following the driver page <http://www.gdal.org/ogr/drv_filegdb.html>,
> I have to install the FileGDB_API_SDK if I want to read/write the gdb
> format.
> I have download the package from ESRI site, but I do not know how to
> install it.
> And I have found this <http://trac.osgeo.org/gdal/wiki/FileGDB>, but it
> seems that I have to re-compile gdal again from the source if I follow the
> guide.
> Any suggestion ?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131211/7b9dc4d8/attachment.html>
