[gdal-dev] ISO WKB
Paul Ramsey
pramsey at cleverelephant.ca
Tue Dec 17 13:38:26 PST 2013
OK, so hide the ISO types from the outside world. No problem.
Is it OK to have getGeometryType and exportToWkb accept wkbVariant
optional parameters?
P.
On Tue, Dec 17, 2013 at 1:03 AM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Selon Paul Ramsey <pramsey at cleverelephant.ca>:
>> Back to this, is it OK?
> As said in http://lists.osgeo.org/pipermail/gdal-dev/2013-December/037738.html,
> I feel a bit unconfortable with the extension of the OGRwkbGeometryType
> enumeration that has possible impacts on other parts of OGR. There's perhaps a
> time where we will touch it, but I'd expect it to ideally embrace Z, M, ZM,
> circular geometries at once. And that would deserve a RFC.
> What do you think of keeping it an internal enumeration of OGR, since that's
> probably all you need for now ?
> "Or have a separate OGRwkbIsoGeometryType enumeration { wkbPointIso, ...
> wkbGeometryCollectionIso, wkbPointIsoZ, ... wkbGeometryCollectionIsoZ }, a
> getIsoGeometryType() method that returns it, and the exportToWkb() methods
> that calls int getGeometryType(OGRwkbVariant eVariant) { return (eVariant ==
> wkbVariantOgc) ? getGeometryType() : getIsoGeometryType(); }"
> I'd be happy to hear about other GDAL developers opinion on this.
>> How are we patching back to SVN? I can convert
>> it into a patch and attach to a ticket, if that's the path.
> git-svn can be used to bridge the 2 worlds, but in my recent experience it has
> been painful to use. So generating a patch and applying it is probably easier.
> Even
> Geospatial professional services
> http://even.rouault.free.fr/services.html
