[gdal-dev] JPEG2000 read performance with OpenJPEG
Even Rouault even.rouault at mines-paris.org
Thu Dec 19 01:52:43 PST 2013
Yes for performance you must adapt your reading pattern to the underlying
structure of the data. You could still have performant RasterIO() if you define
GDAL_CACHEMAX to at least (raster_width * block_height * 4), so that when you
read a scanline there will be enough memory in the block cache to keep all the
blocks that have been read for that scanline.
Instead of using GDALReadBlock(), you could also use GDALRasterIO() but on a
window that is aligned to tile boundaries and dimensions.
The reason for which gdal_translate was more performant than your code is that
it does exactly that : work on block/tile dimensions.
Even
> Hi,
> Just to follow up, once I got GDAL built with OpenJPEG support on Windows I
> found the performance was terrible there as well. So I tried reading in
> blocks and that was obviously the way to do it. The way I was doing it was to
> read a scanline from each rasterband, perhaps 4 different bands for an RGBA
> image, and process all the pixels for a scanline at once. Now I read blocks
> from each rasterband in turn. It completes in a minute or so instead of
> taking 10 minutes without completing one scanline!
> It's interesting because it kind of makes having a codepath based on
> GDALRasterBand::RasterIO() redundant, for my purposes anyway. Originally I
> thought I would have two codepaths based on reading scanlines (especially
> considering I'd written it all before trying JPEG 2000!) and reading blocks
> which were switched between depending on block size. That ends up being a
> chunk of code though, and with the risk of major performance issues it seems
> better just to go with reading blocks. All RasterIO() seems to get you, on
> the surface at least, is the data type conversion. However I found
> GDALCopyWords() which seems to handle that.
> Thanks to whoever wrote the sample code in the ReadBlock() docs, very helpful
> as a start :-).
> Regards,
> Jo Meder
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
