[gdal-dev] newb with gdal vrt file
Luke
lukepinnerau at gmail.com
Thu Dec 19 17:58:06 PST 2013
Your paths are likely wrong. According to the paths in that VRT, the JP2s
should be located in the same directory as the VRT file. If they aren't,
you need to ensure the list of JP2s (/mnt/tx/utmzone15.lst) used to create
the VRT contains complete absolute or relative paths to each JP2.
Luke
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-newb-with-gdal-vrt-file-tp5095176p5095183.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
