[gdal-dev] MrSID JP2 support in Mac DSDK 9
Howard Butler howard at hobu.co
Mon Dec 23 19:37:19 PST 2013
On Dec 23, 2013, at 9:55 AM, Howard Butler <howard at hobu.co> wrote:
> On Dec 23, 2013, at 5:00 AM, Even Rouault <even.rouault at mines-paris.org> wrote:
>> Hi Howard,
>> DSDK v8 or later no longer needs libltkdu.a. The test that should have succeeded
>> and that has not apparently in your case is :
>>       elif test -e "$with_mrsid/lib/libltidsdk.so" \
>>             -o -e "$with_mrsid/lib/libltidsdk.dylib"; then # v8+ .so has kdu
>>         with_jp2mrsid=yes
>> But I don't know if there are specific behaviour for the Mac DSDK
> Ok, I'll fix this up.
No fixup was needed. As part of my "installation," I moved the .dylibs into /usr/local/lib but pointed at the leftover MrSID SDK directory for configuration. The dylibs were not found, and the logic of the test couldn't succeed.
Thanks,
Howard
