[gdal-dev] performance with VRT dataset containing a large number of raster datasets
Dmitriy Baryshnikov bishop.dev at gmail.com
Tue Dec 24 12:22:15 PST 2013
Hi Paolo,
the te option set the output raster size, not the subraster. You have to
use gdal_translate to get subraster and then use gdalwarp.
Also *multi option is preferable to multi threaded execution.
Best regards,
     Dmitry
24.12.2013 21:48, Paolo Corti ?????:
> Hi all
> I am experiencing problems using a VRT dataset built from a large
> directory of .tif files.
> While if a build the VRT from just one of these datasets, gdalwarp
> will work very fast with it, if I use the VRT will all of these
> images, it becomes undefinite times slower.
> Debugging the gdalwarp command, it seems that gdalwarp accesses every
> single raster composing the vrt datasource, even if that single raster
> is not within the extent defined by the -te gdalwarp option.
> Here is the output for a vrt composed by just one single .tif file:
> $ time gdalwarp -te -88.88 20.28 -87.88 21.28 single.vrt single.tiff
> Src=1344,4463,1201x1201 Dst=0,0,1200x1200
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> GDAL: GDALClose(single.vrt, this=0x8ca6ef8)
> GDAL: GDALClose(/home/capooti/training/vrt/srtm_19_08.tif, this=0x8ca9aa8)
> GDAL: GDALClose(/home/capooti/training/vrt/srtm_19_08.tif, this=0x8ca7208)
> GDAL: GDALClose(single.tiff, this=0x8ca7e98)
> GDAL: In GDALDestroy - unloading GDAL shared library.
> real 0m0.137s
> user 0m0.076s
> sys 0m0.052s
> and here is the output for a vrt composed of all of the .tif files:
> capooti at ubuntu:~/training/vrt$ time gdalwarp -te -88.88 20.28 -87.88
> 21.28 all.vrt all.tiff
> Src=7344,16464,1201x1201 Dst=0,0,1200x1200
> GDAL: GDALClose(all.vrt, this=0x9d332b0)
> GDAL: GDALClose(/home/capooti/training/vrt/srtm_18_09.tif, this=0x9d46618)
> GDAL: GDALClose(/home/capooti/training/vrt/srtm_19_08.tif, this=0x9d467c8)
> GDAL: GDALClose(/home/capooti/training/vrt/srtm_35_09.tif, this=0x9d4c1b8)
> GDAL: GDALClose(/home/capooti/training/vrt/srtm_35_10.tif, this=0x9d4c3a8)
> GDAL: GDALClose(/home/capooti/training/vrt/srtm_19_08.tif, this=0x9d30800)
> GDAL: GDALClose(/home/capooti/training/vrt/srtm_35_11.tif, this=0x9d4c630)
> GDAL: GDALClose(all.tiff, this=0x9d33990)
> real 61m12.130s
> user 0m6.076s
> sys 0m18.052s
> Any hint here to prevent gdalwarp to access the unneeded source raster
> files - the defined extent in -te should just hit a couple of ones?
> thanks in advance
> p
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131225/f985d8a9/attachment.html>
