[gdal-dev] Incorrect path after gdal-19-1600-core.msi
Even Rouault
even.rouault at mines-paris.org
Fri Feb 1 09:07:29 PST 2013
Selon xavier lhomme <lhomme.xavier at gmail.com>:
> Hi
> I use the msi file gdal-19-1600-core.msi in order to install gdal on a
> Windows Server 2008 R2. Once the installation completed, the gdal
> installation directory has been added to the Path. The path contains
> %SYSTEMROOT% but doesn't expand this variable anymore.
> If I open a cmdtool, for example neither xcopy is not recognized nor
> ogrinfo,.
> If I reset the path then I reboot my computer it seems to work again.
> Do You have any idea to reset the path after GDAL installation ?
Something to report to https://github.com/gisinternals/buildsystem/issues/new ?
> xav
