[gdal-dev] GDAL Question about the band/frequence information
Wed Feb 6 13:59:44 PST 2013
Shuqing,
GDAL does not have a well defined name for metadata describing a bands
wavelength.  Some data products carry this in their metadata and it
may be carried through via the GDAL generic metadata at either the
band or dataset level.  Running gdalinfo against a file will show such
generic metadata if it exists.  If not, you are out of luck.  :-(  In
any event since there is no consistent approach to this you are going
to be stuck doing product specific things, likely based on researching
the each sensor yourself.
Best regards,
Frank
On Wed, Feb 6, 2013 at 1:51 PM, Shuqing Chen <chenshuqing82 at gmail.com> wrote:
> Hello GDAL Developers,
> I have intergrated your GDAL library in my Multi Spectra analysis Project.
> It works very well and ease to use.
> A question is how can I find the band/frequence information for each band in
> image dataset? Thank you in advance.
> Best regards,
> Shuqing Chen
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
and watch the world go round - Rush    | Geospatial Software Developer
