[gdal-dev] Pixel remap using the warp api question
    Martin Chapman
    chapmanm at pixia.com
    Fri Feb  8 14:35:26 PST 2013
I asked the following a couple of weeks ago and never got a reply.  Frank,
can you comment on this please?
I am trying to remap all "0" value pixels in the source images to the
value "1" in the output image using gdalwarp like so:
warpOptions->padfSrcNoDataReal[bandIndex] = 0;
warpOptions->padfSrcNoDataImag[bandIndex] = NULL;
warpOptions->padfDstNoDataReal[bandIndex] = 1;
warpOptions->padfDstNoDataImag[bandIndex] = NULL;
1. I am setting INIT_DEST=0.
2. not setting UNIFIED_SRC_NODATA.
3. the source images have no defined nodata value.
4. the output image has no defined nodata value.
with no luck.  My question is:  Is gdalwarp supposed to do this?  When I
look at the pixel value of the output image the black pixels are still "0"
and not "1".
My input and output are both 8-bit 3 band images.  I am using gdal 1.9.2.
Best regards,
Martin
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130208/e290227c/attachment.html>
