[gdal-dev] Issue with GDAL WCS 1.1.x request
Robert Kulawik
rob-news at gmx.de
Wed Feb 13 01:59:46 PST 2013
Thank you Jukka,
has someone from the GDAL guys a solution or idea to get a correct WCS
1.1.x response with GDAL? Nobody use this?
Thanks in advance
Robert
Am 08.02.2013 18:25, schrieb Jukka Rahkonen:
> Robert Kulawik <rob-news <at> gmx.de> writes:
>> Hi List,
>> i try to request my Geoserver WCS (GS version 2.2.x, request 1.1.x) with
>> GDAL 1.9.1.
>> Here is the coverage description from Geoserver:
> http://193.175.162.189/geoserver/wcs?request=DescribeCoverage&identifiers=raster_example_20130208_113005_078&VERSION=1.1.0
> http://193.175.162.189/geoserver/wcs?request=DescribeCoverage&identifiers=raster_example_20130208_113005_078&VERSION=1.1.1
>> When i specify the version in the GDAL request, e.g.
>> <WCS_GDAL>
>> <ServiceURL>http://193.175.162.189/geoserver/wcs?</ServiceURL>
>> <CoverageName>raster_example_20130208_113005_078</CoverageName>
>> <Version>1.1.0</Version>
>> </WCS_GDAL>
>> i get the response:
>> C:\OSGeo4W\bin>gdalinfo wcs.xml
>> ERROR 1: java.lang.IllegalArgumentException: The specified dimensional
>> parameter is non-positive.
>> The specified dimensional parameter is non-positive.
>> gdalinfo failed - unable to open 'wcs.xml'.
>> I asked this with a other background in the Geoserver-user list:
> http://osgeo-org.1560.n6.nabble.com/Issue-with-noValue-in-WCS-coverageOfferings-tp5033051.html
>> and it seems, GDAL does not consider the axis swiching in WCS 1.1.x
>> It is possible to specify (or add) the axis order in the GDAL request?
>> Has someone a solution or a idea for this?
>> Thanks in advance
>> Robert
> I tried to investigate this case a bit on the Geoserver user list. The java
> illegal argument error comes from Geoserver and because GDAL is sending BBOX
> coordinates in lat-lon order.
> This is captured from the GetCoverage request that was sent by gdalinfo
> BOUNDINGBOX=-116.917,32.41666843,-116.75033333,32.5833351,
> urn:ogc:def:crs:EPSG::4326
> However, I feel it may be because a bit earlier the same Geoserver has
> responded to DescribeCoverage request that was sent by GDAL as
> <wcs:GridCRS><wcs:GridBaseCRS>urn:ogc:def:crs:EPSG::4326</wcs:GridBaseCRS>
> <wcs:GridType>urn:ogc:def:method:WCS:1.1:2dGridIn2dCrs</wcs:GridType>
> <wcs:GridOrigin>-116.91699999999997 32.5833351</wcs:GridOrigin>
> <wcs:GridOffsets>0.16666667 0.0 0.0 -0.16666667</wcs:GridOffsets>
> <wcs:GridCS>urn:ogc:def:cs:OGC:0.0:Grid2dSquareCS
> </wcs:GridCS></wcs:GridCRS>
> Does gdalinfo build the little GetCoverage request it is sending based on the
> GridOrigin metadata it has queried from WCS server? And is this case the real
> reason for the trouble caused by the wrong GridOrigin and GridOffsets metadata?
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
