[gdal-dev] GeoTIFF with LZW compression Overviews error
Fabian Schindler fabian.schindler at eox.at
Thu Feb 14 01:00:03 PST 2013
Frank,
> I'm assuming you mean gdaladdo is run on y.tif, the output of gdalwarp, right?
Yes, sorry, that's what I meant.
> I tried the steps with a manufactured input file of the same size and
> did not encounter the problem on my system.  The most likely important
> difference is that I am not using libtiff 3.9.4 - I'm using libtiff
> 4.0.x (trunk).  Is there a reason you are using the old style libtiff?
>   Perhaps just because it is what is packaged?  I imagine that is the
> problem.
Yes I'm using the packaged version of libtiff. I guess I'll have to try
the 4.0.x version and report my experiences.
Thanks!
Fabian
