[gdal-dev] OGR WFS from behind NTLMv2 proxy server
Jeremy Palmer JPalmer at linz.govt.nz
Mon Feb 18 14:49:10 PST 2013
>> Try setting GDAL_HTTP_PROXY=host:port and GDAL_HTTP_PROXYUSERPWD=user:pass as environmenet variables / configuration options.
Still can't get it to work. Returns:
ERROR 1: HTTP error code : 407
ERROR 1: Error returned by server : HTTP error code : 407 (0)
FAILURE:
Unable to open datasource `WFS:http://geoportal.doc.govt.nz/arcgis/services/Geop
ortalServices/DOC_Tracks/MapServer/WFSServer' with the following drivers.
Works when I connect via chrome on the same PC.
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
