[gdal-dev] Transform from ground control points
Livneh Yehiyam
yehil at rafael.co.il
Tue Feb 19 07:09:25 PST 2013
Hi
I have an image with 4 control points at the 4 corners. From my understanding, this defines a perspective linear transform (not necesserally affine).
I'm trying to warp it into an orthophoto.
from what I see in the gdalgcptransform code it seems that only an affine transform is created. Is it the correct way of doing this projection, or is gdalgcptransform not the correct way of doing it?
thanks
yehiyam livneh
________________________________________
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE SYSTEMS LTD. (hereinafter "RAFAEL") contains confidential information intended for a specific individual and purpose, may constitute information that is privileged or confidential or otherwise protected from disclosure. If you are not the intended recipient, you should contact us immediately and thereafter delete this message from your system. You are hereby notified that any disclosure, copying, dissemination, distribution or forwarding of this message, or the taking of any action based on it, is strictly prohibited. If you have received this e-mail in error, please notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely delete or destroy any and all electronic or other copies of the original message and any attachments thereof.
