[gdal-dev] gdal_polygonize and polygon edges
    Graeme B. Bell
    grb at skogoglandskap.no
    Wed Feb 20 00:28:15 PST 2013
> Yes visually attractive or smooth polygons is the goal. Thanks again Frank.
> Doing a web search about simplification algorithm i found one named
> '*Ramer-Douglas?Peucker'
> (*http://en.wikipedia.org/wiki/Ramer-Douglas-Peucker_algorithm).
> It appears that 'Geos'' library implement this algorithm. Is this algorithm
> exposed through OGR ?
You could try this:
https://github.com/gina-alaska/dans-gdal-scripts/wiki/Gdal_trace_outline
to get it
1. git clone https://github.com/gina-alaska/dans-gdal-scripts.git
2. go into the directory
3. ./configure
4. make
5. make install
It has a parameter-controlled douglas-peucker algorithm built in, and it is a lot faster than gdal_polygonize, too!
Hope this helps
Graeme.
