[gdal-dev] gdaladdo don't seem to work..
Pietro Rossin pierigis at gmail.com
Mon Feb 25 04:45:19 PST 2013
Hi all
I'll like to add overviews to a 1 bit geotiff
the gdalinfo for this tiff is:
Driver: GTiff/GeoTIFF
Files: test.tif
       test.tfw
       test.aux
Size is 292042, 284413
Coordinate System is `'
Origin = (2311161.564860595900000,5168752.558307543400000)
Pixel Size = (0.426789595821517,-0.426789595819635)
Image Structure Metadata:
  COMPRESSION=CCITTFAX4
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  ( 2311161.565, 5168752.558)
Lower Left  ( 2311161.565, 5047368.049)
Upper Right ( 2435802.052, 5168752.558)
Lower Right ( 2435802.052, 5047368.049)
Center      ( 2373481.808, 5108060.304)
Band 1 Block=256x256 Type=Byte, ColorInterp=Palette
  Description = Layer_1
  NoData Value=0
  Metadata:
    LAYER_TYPE=athematic
    NBITS=1
  Color Table (RGB with 2 entries)
    0: 255,255,255,255
    1: 0,0,0,255
I used:
gdaladdo -r average --config USE_RRD YES test.tif 2 4 8 16
The result is a file called  test.axe 20Gb big and a test.aux file (5Kb)
gdaladdo.exe don't seem to work, in taskmanager it uses 0 to 0.1 cpu%
Gdal 1.9.2 installed with osgeo4w.
By the way, which is the best way to create overviews for this kind of
tiff??
Thankyou
Pietro
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdaladdo-don-t-seem-to-work-tp5036638.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
