[gdal-dev] Dissolve shapefile using GDAL/OGR
Andreas Oxenstierna
ao at t-kartor.se
Tue Feb 26 05:38:26 PST 2013
I would use PostGIS - they have comprehensive, very efficient and in my
experience 100 % correct set of spatial processing tools.
> Hi!
> So, My question is pretty simple.
> I'm developing a software in C++ that uses GDAL/OGR library to handle
> geoprocessing computations. What I need to do now is to dissolve a
> shapefile by a column (similiar to the Quantum GIS tool "Vector >
> Geoprocessing Tools > Dissolve").
> Does GDAL/OGR already support this operation (or eases this somehow)?
> Do I have to implement it by myself? Do I need to use another library
> to easily acomplish this task? (GRASS?).
> Thanks in advance,
> Hugo Benício.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best Regards
Andreas Oxenstierna
T-Kartan Produkt AB
mobile: +46 733 206831
mailto: ao at t-kartor.se
http://www.t-kartor.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130226/3a109eb0/attachment.html>
