[gdal-dev] gdalinfo and ogrinfo file formats
Paul Meems
bontepaarden at gmail.com
Wed Jan 2 05:28:44 PST 2013
Hi all,
First I wish everybody a happy 2013!
With MapWindow GIS we're using gdal and ogr and we are now in the process
of include the functionality of the utility programs, like gdalinfo.exe,
ogrinfo.exe, gdal_translate.exe, ogr2ogr.exe, etc.
This functionality is added to our core C++ base called MapWinGIS. This
work is almost done.
We're now in the progress of creating C#/WinForms tools on top of these
functionality to be used in MapWindow. We are going to use *gdalinfo
--formats* and *gdalinfo --format the_format *to get the relevant data we
need to create for example a file open box. This works fine since the
extension can be retrieved from using the --format command.
For example *gdalinfo --format VRT *returns
VRT format: Format Details:
Short Name: VRT
Long Name: Virtual Raster
Extension: vrt
Help Topic: gdal_vrttut.html
Supports: Create() - Create writeable dataset.
Supports: CreateCopy() - Create dataset by copying another.
Creation Datatypes: Byte Int16 UInt16 Int32 UInt32 Float32 Float64 CInt16
CInt32 CFloat32 CFloat64
The same we want to do for the ogr2org.
*--formats* will give us the available file formats but I can't find a
command that will give me the expected extension for the file format. I was
expecting something like *ogrinfo --format "ESRI Shapefile"* that would
return something like
ESRI Shapefile format: Format Details:
Short Name: sf
Long Name: ESRI Shapefile
Extension: shp
Help Topic: drv_shapefile.html
Am I missing something or isn't this available for ogr?
Thanks,
Paul
*Paul Meems *
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130102/3c118db0/attachment-0001.html>
