[gdal-dev] FW: point within polygon c++ API problem
Ran, Limei
lran at email.unc.edu
Wed Jan 2 19:07:52 PST 2013
Hello Frank,
I think the fragmentation is caused by how the program is compiled. I did a test using the attached test code with point within polygon function. I appreciate if you can suggest how to compile it correctly with static option.
When I compiled it in the following way, it worked:
> g++ -I/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/gdal-1.9.1/local/include -I/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local/include test_geos.cpp -o test_geos -L/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/gdal-1.9.1/local/lib -lgdal -L/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local/lib -lgeos_c
> ./test_geos
Testing point in polygon
Set point
Completed set point
Set polygon
Completed set polygon
Check point within polygon
Point is not in the polygon
When I compiled it using the static way (which is the same as our API programs), it has segmentation fault:
> g++ -I/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/gdal-1.9.1/local/include -I/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local/include -I/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/proj-4.8.0/local/include test_geos.cpp -o test_geos -static -pthread -L/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/gdal-1.9.1/local/lib -lgdal -L/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local/lib -lgeos_c -lgeos -L/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/proj-4.8.0/local/lib -lproj -ldl
> ./test_geos
Set point
Completed set point
Set polygon
Segmentation fault
We have been compiling our GDAL C++ APIs with static -pthread. So, the programs can be used without recompiling on different systems. Could I be doing something wrong here?
Thank you and happy new year,
Limei
Center for Environmental Modeling for Policy Development
Institute for the Environment
University of North Carolina at Chapel Hill
________________________________________
Sent: Thursday, December 20, 2012 10:20 AM
To: Frank Warmerdam
Subject: RE: [gdal-dev] FW: point within polygon c++ API problem
Hello Frank,
I did a small testing codes (see the following lines) on GEOS in my c++ API by following the sample test codes in http://trac.osgeo.org/gdal/browser/trunk/autotest/pymod/ogrtest.py.
//test GEOS
OGRPoint *pnt1;
pnt1->setX (10);
pnt1->setY (20);
OGRPoint *pnt2;
pnt1->setX (30);
pnt1->setY (20);
OGRGeometry *result;
result = pnt1->Union( pnt2 );
if ( result == NULL )
printf ("\tGEOS is not avaiable...\n");
exit ( 1 );
pnt1->empty();
pnt2->empty();
The program has segmentation fault when reaching Union. So, I guess somehow GEOS is not installed or configured right. Here is config info for my GDAL configuration:
config.log:ac_cv_lib_geos_c_GEOSversion=yes
config.log:ac_cv_prog_GEOS_CONFIG=/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local/bin/geos-config
config.log:GEOS_CFLAGS='-I/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local/include'
config.log:GEOS_CONFIG='/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local/bin/geos-config'
config.log:GEOS_LIBS='-L/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local/lib -lgeos_c'
config.log:GEOS_VERSION='3.3.6'
config.log:HAVE_GEOS='yes'
config.status:S["GEOS_CONFIG"]="/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local/bin/geos-config"
config.status:S["GEOS_VERSION"]="3.3.6"
config.status:S["HAVE_GEOS"]="yes"
config.status:S["GEOS_CFLAGS"]="-I/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local/include"
config.status:S["GEOS_LIBS"]="-L/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local/lib -lgeos_c"
When I compiled my C++ API, if I just have: #include <geos.h> and $(LIBPATH_GEOS) -lgeos, I get errors:
/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/gdal-1.9.1/ogr/ogrgeometryfactory.cpp:1481: undefined reference to `GEOSGeomTypeId'
/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/gdal-1.9.1/ogr/ogrgeometryfactory.cpp:1481: undefined reference to `GEOSisEmpty'
I can only compile my c++ codes with: #include <geos_c.h> and $(LIBPATH_GEOS) -lgeos_c -lgeos
Thank you very much,
Limei
-----Original Message-----
From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On Behalf Of Frank Warmerdam
Sent: Wednesday, December 19, 2012 8:51 PM
To: Ran, Limei
Subject: Re: [gdal-dev] FW: point within polygon c++ API problem
Limei,
For what it's worth, I looked over the code and your approach seemed fine. I'm not sure why it crashed. I didn't try to build a sample to demonstrate the problem on my tree. If you could prepare a fairly self contained simple demonstration it might be possible to get more help.
Best regards,
Frank
On Wed, Dec 19, 2012 at 12:18 PM, Ran, Limei <lran at email.unc.edu> wrote:
> Hello Even,
> Since you helped me on GEOS compiling with GDAL, I think you may have
> ideas on what went wrong with my codes in the following. Could you
> tell me what you think on my segmentation fault error?
> Thank you,
> Limei
> From: Ran, Limei
> Sent: Tuesday, December 18, 2012 3:21 PM
> To: gdal-dev at lists.osgeo.org
> Subject: point within polygon c++ API problem
> Hello,
> I am working on a C++ codes which reads polygon from polygon shapefile
> to see whether a point is within a polygon. But, I got segmentation
> fault for pt.within (poGeometry). Could you tell me where I may have errors.
> 1. GDAL 1.9.1 is compiled with currect GEOS 3.3.6
> 2. My c++ program compiled with GDAL.
> 3. Here are my codes:
> float x = grid.x[col];
> float y = grid.y[row];
> OGRPoint pt;
> pt.setX( x );
> pt.setY( y );
> printf ("\tSet point\n");
> OGRFeature *poFeature;
> poLayer->ResetReading();
> while( (poFeature = poLayer->GetNextFeature()) != NULL )
> OGRFeatureDefn *poFDefn = poLayer->GetLayerDefn();
> int iField;
> OGRGeometry *poGeometry;
> poGeometry = poFeature->GetGeometryRef();
> if( poGeometry != NULL && ( poGeometry->getGeometryType() )
> == wkbPolygon )
> printf ("\tGot polygon\n");
> if ( pt.Within ( poGeometry ) )
> { //find the polygon where point is within and get item
> values
> printf ("\tpoint in polygon\n");
> I got segmentation fault when processing gets: if ( pt.Within (
> poGeometry
> Thank you,
> Limei
> gdal-dev mailing list
and watch the world go round - Rush | Geospatial Software Developer
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130103/787cd9dc/attachment.ksh>
