[gdal-dev] ogr2ogr
Yves Jacolin
yjacolin at free.fr
Fri Jan 4 02:27:47 PST 2013
Hello,
Le vendredi 4 janvier 2013 11:17:43 Uffe Kousgaard a écrit :
> Hello,
> Thank you, yes I had just found the exe files in a sub folder.
> But it still doesn't write the TAB file correct.
> If I use MIF instead as output format, it changes Numeric(4,0) fields
> into Integer(4). There is no such thing as Integer(4) in MIF.
> It is either Decimal(4,0) or just Integer / SmallInt. But at least the
> UTF-8 strings come out correct.
> So, it seems like being a matter of incorrect writing of TAB and MIF
> rather than reading the SHP and codepage.
Yes I am aware of this issue. Some french user report this a few monthes ago,
there are some other similar issues with TAB format.
Y.
Yves Jacolin
