[gdal-dev] DBF handling
Luca Sigfrido Percich
sigfrido at tiscali.it
Fri Jan 4 05:11:59 PST 2013
Uffe,
I have had a similar problems with TeleAtlas shapefiles with IDs stored
as long Numeric fields.
I resorted to the ogr2ogr -fieldTypeToString option [1] to tell ogr to
convert to string all the mumeric fields, which is still an imperfect
workaround but at least will keep you from manually changing the DBF
files. Unfortunately the conversion is applied to all the field of the
specified type.
Hope this helps
Sig
[1] http://www.gdal.org/ogr2ogr.html
Il giorno ven, 04/01/2013 alle 11.37 +0100, Uffe Kousgaard ha scritto:
> When DBF files has numeric fields with values > 2GB, processing fails
> and all values come out as -2147483648.
> My current work-around is manually changing the fields from Numeric to
> Char (changing the header of the DBF), but it is really an ugly hack and
> spaces for padding are wrong (numeric fields are right-aligned, while
> char-fields are left-aligned internally).
> It would be nice if at least int64 was used for integers in OGR, rather
> than int32. Large integers are typically used as identifiers in
> databases such as TomTom, OSM etc.
> Has this been reported before?
> Regards
> Uffe Kousgaard
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
_____________
PRIVACY
Le informazioni contenute in questo messaggio sono riservate e confidenziali. Il loro utilizzo e' consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo dal Suo Sistema e a distruggere le varie copie o stampe, dandone gentilmente comunicazione all’indirizzo mail del mittente. Ogni utilizzo improprio e' contrario ai principi del D.lgs 196/03 e alla legislazione europea (Direttiva 2002/58/CE).
PRIVACY
