[gdal-dev] New OGR driver to read OpenStreetMap .osm / .pbf files
Stefan Keller sfkeller at gmail.com
Tue Jan 8 17:11:21 PST 2013
Even,
Thanks for the fast response!
2013/1/9 Even Rouault <even.rouault at mines-paris.org>:
> (Just curious what in the doc makes you call it "stable", and what you
> consider as "stable")
Just the fact that it's there and especially that is't also in the
overview table alongside with all other (stable) drivers
http://www.gdal.org/ogr/ogr_formats.html .
Yours, Stefan
> Le mercredi 09 janvier 2013 01:02:22, Stefan Keller a écrit :
>> Hi Even
>> Documentation of OpenStreetMap driver suggest its stable
>> - but when I
>> recently installed the newest OGR version on a linux it was'nt there.
>> Is it not yet stable enough?
>> If not, what do you recommend?
>> Should I include the tagged version (currently 1.9.2) and add the
>> trunk version (subdirectory) of the OpenStreetMap driver?
> Stephan,
> The OSM driver is only available in the trunk version (definitely not in the
> 1.9.X branch which is in maintenance mode only), the future 1.10 to be
> released (hopefully in the following weeks).
> Copying the OSM directory from trunk into 1.9 will work. It won't compile
> since there are a few services in port/ that have been added in trunk and are
> needed by the OSM driver.
> So if you are interested in the OSM driver, I suggest that you just check out
> and compile the trunk and use it. It passes currently the autotest regresssion
> suite on both Linux and Windows, so I consider it stable enough for wide
> testing. And we definitely need beta testers for the release anyway !
> Best regards,
> Even
