[gdal-dev] does gdal support multiple simultaneous writers to raster
Jan Hartmann j.l.h.hartmann at uva.nl
Fri Jan 11 01:43:07 PST 2013
I'v tried this in a Cloud environment with multiple VMs writing to the
same shared file location. I didn't use tiles, so the results where
negative. It would be a great asset for Cloud environments, however. Is
it in principle possible to build such a facility into GDAL, and if yes,
what kind of funding would it require?
Jan
On 01/11/2013 02:32 AM, Frank Warmerdam wrote:
> Paul,
> Generally speaking - no - GDAL does not now support multi-threaded
> writing.  Part of this is due to the way stuff gets write-flushed out
> of the block cache and partly it is just that none of GDAL supports
> multiple threading on a single dataset.
> This statement is based on the assumption it is all in one process.
> If you want to run different processes with the output to a
> pre-existing "fixed location" format like uncompressed GeoTIFF with
> tiles that is all preinitialized to some real value then you could
> certainly use one output file for many writers as long as case is
> taken to not have multiple processes write to the same tile.  But GDAL
> isn't doing anything to make this easy.
> Best regards,
> Frank
> On Thu, Jan 10, 2013 at 4:12 PM, Kennedy, Paul <P.Kennedy at fugro.com.au> wrote:
>> I am looking to parallelize a long duration gridding process, and was
>> wondering if GDAL can support multiple simultaneous writers from processess?
>> I am not sure if any of the underlying raster formats support this?
>> thanks in advance.
>> regards
>> pk
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130111/dcba8b7a/attachment.html>
