[gdal-dev] which formats support subdatasets?
Etienne Tourigny
etourigny.dev at gmail.com
Fri Jan 11 05:23:22 PST 2013
On Fri, Jan 11, 2013 at 11:03 AM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Selon Etienne Tourigny <etourigny.dev at gmail.com>:
>> Hi,
>> I'd just like to point out a patch I have submitted to report which
>> raster drivers support subdatasets, using the DMD_SUBDATASETS metadata
>> item.
>> I have also modified gdalinfo and format docs.
>> http://trac.osgeo.org/gdal/ticket/4902
>> For example:
>> $ gdalinfo --format hdf4
>> Format Details:
>> Short Name: HDF4
>> Long Name: Hierarchical Data Format Release 4
>> Extension: hdf
>> Help Topic: frmt_hdf4.html
>> Supports: Subdatasets
> I've looked at the patch and it seems good. I'm not sure I would have added a
> new column in the table, but if you think it is usefull, keep it. It would
> perhaps be good to mention in gdal_datamodel.dox, in the SUBDATASETS section,
> that drivers that support them advertize the DMD_SUBDATASETS capability. And I
> think that swig/include/gdalconst.i should also be edited to add the new
> constant. After that please commit.
I though adding the info to frmt_various.html was the most
appropriate, but it is a bit intrusive. Should it be elsewhere, like
the individual driver docs or in gdal_datamodel?
I also though about adding an "s" key to the output of "--formats"
format support string e.g. (rw+vs)
I'll make the other changes you suggest.
> I'm not sure it is appropriate to backport in 1.9 however (new feature, output
> of gdalinfo --format modified). 1.10 should be out soon hopefully.
I also don't think it's appropriate adding this to 1.9
>> Regards,
>> Etienne
>> On Tue, Nov 20, 2012 at 10:43 AM, Etienne Tourigny
>> <etourigny.dev at gmail.com> wrote:
>> > Hi
>> > I'd like to be able to identify which raster and vector formats
>> > support subdatasets (or multipl layers).
>> > A quick grep search (grep SUBDATASETS frmts/*/*.cpp) showed which GDAL
>> > drivers can report subdatasets.
>> > Am I missing something?
>> > I think it would be nice to include this info in the driver summary
>> > page - should I just edit the html or is there some other file to
>> > edit?
>> > I was wondering how to find that out for OGR drivers - or do all
>> > drivers support multiple layers in one datasource?
>> > Regards,
>> > Etienne
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
