[gdal-dev] does gdal support multiple simultaneous writers to raster
Jan Hartmann
j.l.h.hartmann at uva.nl
Sat Jan 12 08:12:10 PST 2013
This is about the same acceleartion (2-3 times) as I got on jobs running
for a few days. My impression is that distributed tile processing would
give much more dramatic results.
On 01/12/2013 03:57 PM, Even Rouault wrote:
> Le samedi 12 janvier 2013 15:08:55, Jan Hartmann a écrit :
>> You probably know this, but there is an option to let gdalwarp use more
>> cores: -wo NUM_THREADS=ALL_CPUS. It gives some improvement, but not
>> really staggering.
> Do you use Proj 4.8.0 ? If not, that might explain why you don't see a
> significant improvement. The performance gain is also much more significant with
> complex resampling kernels. With nearest resampling, most of the time is spent
> in I/O. Increasing the warping memory buffer might also help to benefit from
> parallelization.
> For example (debug non-optimized build) :
> - 1 thread, nearest :
> $ time gdalwarp world_4326.tif out.tif -t_srs EPSG:3857 -overwrite -wo
> NUM_THREADS=1 -wm 512
> Creating output file that is 8183P x 8201L.
> Processing input file world_4326.tif.
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> real 0m6.390s
> user 0m5.940s
> sys 0m0.440s
> - 4 threads, nearest :
> NUM_THREADS=4 -wm 512
> real 0m3.482s
> user 0m6.330s
> sys 0m0.700s
> - 1 thread, bilinear :
> NUM_THREADS=1 -wm 512 -rb
> real 0m18.387s
> user 0m17.840s
> sys 0m0.510s
> - 4 threads, bilinear :
> NUM_THREADS=4 -wm 512 -rb
> real 0m8.052s
> user 0m20.000s
> sys 0m0.550s
> - 1 thread, cubic :
> NUM_THREADS=1 -wm 512 -rc
> real 0m35.724s
> user 0m35.010s
> sys 0m0.620s
> - 4 threads, cubic :
> NUM_THREADS=4 -wm 512 -rc
> real 0m13.274s
> user 0m39.530s
> sys 0m0.560s
> - 1 thread, lanczos :
> NUM_THREADS=1 -wm 512 -r lanczos
> real 2m21.269s
> user 2m20.460s
> sys 0m0.400s
> - 4 threads, lanczos :
> NUM_THREADS=4 -wm 512 -r lanczos
> real 0m51.852s
> user 2m36.520s
> sys 0m0.750s
>> Splitting up operations over individual tiles would
>> really fasten up things. Even if I use only one VM, I can define 32
>> cores, and it would certainly be interesting to experiment with programs
>> like MPI to integrate multiple VMs into one computing cluster.
>> Jan
>> On 01/12/2013 02:38 AM, Kennedy, Paul wrote:
>>> Hi,
>>> Yes, we are pretty sure we will see a significant benefit. The
>>> processing algorithms are CPU bound not io bound. Our digital terrain
>>> model interpolations often run for many hours ( we do them overnight)
>>> but the underlying file is only a few gigabytes. If we split them into
>>> multiple files of tiles and run each on a dedicated process the whole
>>> thing is quicker, but this is messy and results in a stitching error.
>>> Another example is gdalwarp. It takes quite some time with a large
>>> data set and would be. A good candidate for parallelisation, as would
>>> gdaladdo.
>>> I believe slower cores but more of them in pcs are the future. My pc
>>> has 8 but they rarely get used to their potential.
>>> I am certain there are some challenges here, that's why it is
>>> interesting;)
>>> Regards
>>> pk
>>> On 11/01/2013, at 6:54 PM, "Even Rouault"
>>> <even.rouault at mines-paris.org <mailto:even.rouault at mines-paris.org>>
>>> wrote:
>>>> Re: [gdal-dev] does gdal support multiple simultaneous writers to raster
>>>> Hi,
>>>> This is an intersting topic, with many "intersecting" issues to deal
>>>> with at
>>>> different levels.
>>>> First, are you confident that in the use cases you imagine that I/O
>>>> access won't
>>>> be the limiting factor, in which case serialization of I/O could be
>>>> acceptable
>>>> and this would just require an API with a dataset level mutex.
>>>> There are several places where parallel write should be addressed :
>>>> - The GDAL core mechanisms that deal with the block cache
>>>> - Each GDAL driver where parallel write would be supported. I guess
>>>> that GDAL
>>>> drivers should advertize a specific capability
>>>> - The low-level library used by the driver. In the case of GDAL, libtiff
>>>> And finally, as Frank underlined, there are intrinsic limitations due
>>>> to the
>>>> format itself. For a compressed TIFF, at some point, you have to
>>>> serialize the
>>>> writing of the tile, because you cannot kown in advance the size of the
>>>> compressed data, or at least have some coordination of the writers so
>>>> that a
>>>> "next offset available" is properly synchronized between them. The
>>>> compression
>>>> itself could be serialized.
>>>> I'm not sure however if what Jan mentionned, different process,
>>>> writing the same
>>>> dataset is doable.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130112/cbb42f7d/attachment.html>
