[gdal-dev] RPC transform
Dmitry Baryshnikov
bishop.dev at gmail.com
Wed Jan 16 07:58:54 PST 2013
Hi Ivan,
Look here:
http://www.gdal.org/gdal__alg_8h.html#af4c3c0d4c79218995b3a1f0bac3700a0
You can find such options:
RPC_HEIGHT: a fixed height offset to be applied to all points passed
in. In this situation the Z passed into the transformation function
is assumed to be height above ground, and the RPC_HEIGHT is assumed
to be an average height above sea level for ground in the target scene.
RPC_HEIGHT_SCALE: a factor used to multiply heights above ground.
Usefull when elevation offsets of the DEM are not expressed in
meters. (GDAL >= 1.8.0)
RPC_DEM: the name of a GDAL dataset (a DEM file typically) used to
extract elevation offsets from. In this situation the Z passed into
the transformation function is assumed to be height above ground.
This option should be used in replacement of RPC_HEIGHT to provide a
way of defining a non uniform ground for the target scene (GDAL >=
1.8.0)
* RPC_DEMINTERPOLATION: the DEM interpolation (near, bilinear or cubic)
Best regards,
Dmitry
16.01.2013 19:54, Ivan Lucena ?????:
> Yehiyam,
> For that kind of issue my advise is to run in debugging mode. The GDAL
> transformation engine must have an internal pixel geolocation defined.
> It is probably CENTER of the pixel, as in AREA. I am not sure. In that
> case the returning pixel/line refers to AREA and you might need to do
> the adjustment. But again, I would debug it to make sure. We have
> instructions on how to debug GDAL using VS and NetBeans on wiki. I
> just can't find it. I can't find anything about the RPC_DEM either.
> Where did you get it?
> Regards,
> Ivan
> On 1/16/13 7:40 AM, Livneh Yehiyam wrote:
>> Hi
>> I have a question about the RPC transform implemented in gdal_rpc.cpp.
>> If a dem file is specified in the transform options (RPC_DEM) the
>> file is sampled to retrieve the elevation of the transformed point.
>> In the case where the dem file is a DTED file (which defines
>> AREA_OR_POINT to POINT), shouldn't the pixel/line values in the dem
>> file be offset by half a pixel to get the correct height?
>> Thanks
>> Yehiyam
>> ________________________________________
>> This message (including any attachments) issued by RAFAEL- ADVANCED
>> DEFENSE SYSTEMS LTD. (hereinafter "RAFAEL") contains confidential
>> information intended for a specific individual and purpose, may
>> constitute information that is privileged or confidential or
>> otherwise protected from disclosure. If you are not the intended
>> recipient, you should contact us immediately and thereafter delete
>> this message from your system. You are hereby notified that any
>> disclosure, copying, dissemination, distribution or forwarding of
>> this message, or the taking of any action based on it, is strictly
>> prohibited. If you have received this e-mail in error, please notify
>> us immediately by e-mail mailto:lawraf at rafael.co.il and completely
>> delete or destroy any and all electronic or other copies of the
>> original message and any attachments thereof.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130116/683fc7c3/attachment-0001.html>
