[gdal-dev] RPC transform
Dmitriy Baryshnikov bishop.dev at gmail.com
Wed Jan 16 10:51:58 PST 2013
Hi Frank,
I only want to note that the default is bilinear interpolation of the DEM.
Part of the code: const char *pszDEMInterpolation =
CSLFetchNameValueDef( papszOptions, "RPC_DEMINTERPOLATION", "bilinear" );
Best regards,
     Dmitriy
16.01.2013 22:47, Frank Warmerdam ?????:
> Yehiyam,
> I do not see why you think the AREA_OR_POINT value ought to have any
> influence on how DEM values are interpolated.
> Note that a PixelIsPoint GeoTIFF file will already result in a GDAL
> GeoTransform that is offset by half a pixel.  The GDAL GeoTransform
> always treats pixels as areas, and GDAL interpolators - presumably
> including the for RPCs - should treat the pixel value as being at the
> center of the pixel area for the purpose of interpolation (regardless
> of whether that value is point or area).
> On the other hand, I am denying the possibility that the RPC DEM
> interpolation is always off by half a pixel.  I haven't actually
> looked closely at that code lately and the RPC code is not so very
> well tested and validated.
> Best regards,
> Frank
> On Wed, Jan 16, 2013 at 4:40 AM, Livneh Yehiyam <yehil at rafael.co.il
> <mailto:yehil at rafael.co.il>> wrote:
>     Hi
>     I have a question about the RPC transform implemented in gdal_rpc.cpp.
>     If a dem file is specified in the transform options (RPC_DEM) the
>     file is sampled to retrieve the elevation of the transformed point.
>     In the case where the dem file is a DTED file (which defines
>     AREA_OR_POINT to POINT), shouldn't the pixel/line values in the
>     dem file be offset by half a pixel to get the correct height?
>     Thanks
>     Yehiyam
>     ________________________________________
>     This message (including any attachments) issued by RAFAEL-
>     ADVANCED DEFENSE SYSTEMS LTD. (hereinafter "RAFAEL") contains
>     confidential information intended for a specific individual and
>     purpose, may constitute information that is privileged or
>     confidential or otherwise protected from disclosure. If you are
>     not the intended recipient, you should contact us immediately and
>     thereafter delete this message from your system. You are hereby
>     notified that any disclosure, copying, dissemination, distribution
>     or forwarding of this message, or the taking of any action based
>     on it, is strictly prohibited. If you have received this e-mail in
>     error, please notify us immediately by e-mail
>     mailto:lawraf at rafael.co.il <mailto:lawraf at rafael.co.il> and
>     completely delete or destroy any and all electronic or other
>     copies of the original message and any attachments thereof.
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com <mailto:warmerdam at pobox.com>
> light and sound - activate the windows | http://pobox.com/~warmerdam
> <http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130116/42bf0559/attachment-0001.html>
