[gdal-dev] Giventiff with colortable, how do i assign one of the colors to be an alpha channel
Even Rouault
even.rouault at mines-paris.org
Wed Jan 16 12:17:25 PST 2013
Le mercredi 16 janvier 2013 20:58:51, Isaac Gerg a écrit :
> Even,
> Thanks for your quick response.
> I believe I understand that three options you presented me. I believe
> option 1 is viable but like you mentioned will only work with GDAL
> software. Options 2 and 3 are good but, especially with option 3, the
> resulting tifs are too large.
> I have 20 .tif which are 3MB a piece. Together, they form trackline of a
> sensor data. I would like to load this information into a WMS server for
> display in Google Earth or Arc Explorer. Currently I am using Geoserver.
> Anyways, I must mosaic these 20 .tifs together. These tifs are indexed
> images with a colormap. Here is my current algorithm:
> 1. Expand images to RGBA using gdal_translate
> 2. Rotate images north up using gdal_warp
> 3. Mosiac images using gdal_merge with -co COMPRESS=LZW -co PREDICTOR=1 -ot
> Byte -co TILED=YES -n 0
> At this point, I now have an RGBA image that is huge (300MB). With all the
> tile collections I must process, 300MB is too big. I was thinking the
> total would be around (20 tiles)*(3MB per tile) = 60MB. 300 is simply
> unacceptable.
> 4. Run the gdal_retile to make image pyramid. This will yeild a size that
> is roughly twice that of my mosiac.
> Is there any way I can make the RGBA file in step 3 smaller in size
> specifically to match the theoretical size of 60MB?
You can try rgb2pct.py on the mosaic
Or you can also try to gdal_translate -co COMPRESS=LZW on the mosaic, since
I'm not sure how efficient the compression done by gdal_merge will be.
