[gdal-dev] gridding binary data
    David Hoese
    dhoese at gmail.com
    Wed Jan 23 08:57:37 PST 2013
Hi Norman,
Yes this sounds like it should work.  I'll try it when I get a chance.
If I made a geotiff with no navigation(WKT) and had X,Y,Z as individual
bands would that work?  How do I tell gdal_grid which dimension or band
is X, which is Y, and which is Z?  Thanks.
Could you please CC me in any replies, I get the digest and it's easier
to reply if I get the original email.
-Dave
On 1/23/13 10:30 AM, nhv at cape.com wrote:
> Dave
> Seems to me this is a point not a raster process you are looking for
> e.g.  How do I make a surface from a bunch of discrete points ?
> So instead of having 3 bands of raster you want a stream of XYZ triplets
> you can then submit these to gdal_grid or other tools that work with discrete
> data
> pseudo python  assuming you have read your files into numpy arrays
> XYZ  = array( zip( bandX.flatten(), bandY.flatten(), bandZ.flatten() ) )
> convert XYZ to any OGR format
> call gdal_grid
> HTH
> Norman
