[gdal-dev] libFileGDBAPI.so not found with compiling gdal 1.9.2 on openSUSE 12.2 x64.
Donovan Cameron
sault.don at gmail.com
Fri Jan 25 12:54:17 PST 2013
I've tested compiling the 64bit gdal-1.9.2 from the tar.gz source file:
./configure --with-fgdb=/usr/lib64/FileGDB_API
And it completes successfully where I can see the FileGDB driver
read/write format in the output of ogrinfo --formats.
There must be something in this SPEC file that is causing a conflict
so that that the .so for the FileGDB driver can't be found, even after
it's registered with ldconfig.
On Fri, Jan 25, 2013 at 11:05 AM, Donovan Cameron <sault.don at gmail.com> wrote:
> Thanks for the suggestion Jan.
> I tried to compile the 32-bit libgdal with the 32bit FileGDB_API but
> still throws the same error...
> Is it possible that the osc tool is looking inside it's build
> environment at /tmp or /usr/tmp instead of my local user files at
> /usr/lib64?
> I might take this problem to the package maintainer for libgdal on
> openSUSE 12.2 to see if they have attempted to compile with FileGDB
> support.
> On Fri, Jan 25, 2013 at 1:19 AM, Jan Heckman <jan.heckman at gmail.com> wrote:
>> Hi,
>> On windows, using visual studio (2008 and 2012), I could compile both 32
>> bits and 64 bits, but only the 32 bits version actually worked.
>> I haven't tried to figure out why the 64 bits version didn't work, 32 bits
>> was good enough for me.
>> Hope this is an option for you as well,
>> Jan
>> On Fri, Jan 25, 2013 at 5:23 AM, Donovan Cameron <sault.don at gmail.com>
>> wrote:
>>> Looks like over in the [qgis-user] list, someone is having similar
>>> problems:
>>> https://groups.google.com/d/msg/qgis_user_remote/B2J9sOsSLbo/BIpAHZ84bhgJ
>>> On Thu, Jan 24, 2013 at 9:05 PM, Donovan Cameron <sault.don at gmail.com>
>>> wrote:
>>> > I can't seem to compile GDAL with FileGDB support on openSUSE.
>>> > I'm compiling locally using the OBS tools (osc) and have checked-out
>>> > the libgdal package from the Application:Geo project.
>>> > Steps I've taken:
>>> > 1) Download FileGDB_API_1_2-64.tar.gz
>>> > 2) tar xzvf FileGDB_API_1_2-64.tar.gz -C /usr/lib64/
>>> > 3) export LD_LIBRARY_PATH=/usr/lib64/FileGDB_API/lib
>>> > cd /usr/lib64/FileGDB_API/samples
>>> > make
>>> > cd bin
>>> > ./Querying #Works, so the API is fine.
>>> > 4) su -
>>> > $ vi /etc/ld.so.conf.d/fgdb.conf #Added a single entry:
>>> > $ ldconfig #A grep of this with the -v flag shows it registered fine
>>> > 5) #Some openSUSE specific stuff, b/c I'm building locally via the OBS
>>> > $ zypper in osc
>>> > cd /home/saultdon/Development/obs
>>> > osc co Application:Geo libgdal
>>> > cd Application:Geo/libgdal
>>> > vi libgdal.spec #added "--with-fgdb=/usr/lib64/FileGDB_API" in
>>> > %configure section
>>> > #I also did a test build without that configure param. first and it
>>> > compiled fine with working RPMs
>>> > osc build openSUSE_12.2 x86_64 libgdal.spec --clean
>>> > Resulting Error:
>>> > [ 209s] checking for libFileGDBAPI.so in in
>>> > /usr/lib64/FileGDB_API/lib... configure: error: not found.
>>> > [ 209s] error: Bad exit status from /var/tmp/rpm-tmp.7SOa8g (%build)
>>> > [ 209s] RPM build errors:
>>> > [ 209s] Bad exit status from /var/tmp/rpm-tmp.7SOa8g (%build)
>>> > The buildroot was: /var/tmp/build-root
>>> > libFileGDBAPI.so file exists, ldconfig registered it, and the API test
>>> > worked fine, the env. var. LD_LIBRARY_PATH is also set, but I don't
>>> > even think that's necessary. I only had to set that to get the API
>>> > test to work.
>>> > I'm not sure where this is going wrong. If anyone has any input or
>>> > needs more information, let me know.
>>> > Thanks!
>>> > Donovan
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
