[gdal-dev] fails to build with popler trunk
Even Rouault even.rouault at mines-paris.org
Mon Jan 28 07:47:11 PST 2013
Selon Joaquim Luis <jluis at ualg.pt>:
> Hi,
> FYI
> I tried to build (on Windows) with poppler trunk but got the errors
> below, so had to go back to my working 0.20.0 version.
> If wished, I can open a ticket on this issue.
As documented in nmake.opt, adding POPPLER_0_23_OR_LATER=YES in nmake.local
should fix it. Upgrade both your GDAL trunk and poppler git to the latest
versions. Support for the latest poppler git is in the very last revisions of
GDAL trunk.
