[gdal-dev] shape file to GMT dem file
Tyler Mitchell
tyler.mitchell at actian.com
Tue Jan 29 14:11:34 PST 2013
Do you have elevation data stored in the source data somewhere? You can convert lines to points using QGIS Vector tool -> Extract Nodes, but if you do not have elevation values stored in the attribute table for the lines, it won't help you :)
Feel free to share a zipped set of files with me (directly) if you want me to take a peek.
Tyler
On 2013-01-29, at 1:28 PM, Murat BEYHAN wrote:
> Dear Mitchell,
> Thanks for repply me.
> As you say I have to obtain point data first. If I would able to obtain xyz data it will be easy using GMT xyz2grd.
> But my problem I could not do that. So I produced point data using ogr2ogr command and it is drawn by qgis well
> The picture on this mail. Lines belongs shapefile and points belongs GMT data. But there is a problem its atribute table are null
> and ogrinfo gives 0.0 for the field structure. So is this normal or not. And I couldn't achieve to use gdal_grid using GMT data file.
> Do you have any idea, please.
> Thanks
> murat at murat:~/maps$ ogr2ogr -f "GMT" -nlt point test1.gmt e34c3_n.shp
> murat at murat:~/maps$ ogrinfo -so -al test1.gmt
> INFO: Open of `test1.gmt'
> using driver `GMT' successful.
> Layer name: test1
> Geometry: Point
> Feature Count: 341440
> Extent: (697857.170000, 4597069.190000) - (708674.200000, 4611236.780000)
> Layer SRS WKT:
> (unknown)
> UserId: Real (0.0)
> FNODE_: Real (0.0)
> TNODE_: Real (0.0)
> LPOLY_: Real (0.0)
> RPOLY_: Real (0.0)
> LENGTH: Real (0.0)
> CVRGE34C3#: Integer (0.0)
> CVRGE34C3-: Integer (0.0)
> DETAY: String (0.0)
> SEMBOL: Integer (0.0)
> YUKSEKLIK: Real (0.0)
> On Tue, 29 Jan 2013 12:05:17 -0800, Tyler Mitchell wrote
> > gdal_grid command can convert OGR to GDAL formats, but you need to only have point data. Your line shape file won't work with it.
> > So if you can convert your lines into a set of points, and you will need a Z or elevation point or attribute to point gdal_grid to.
> > Perhaps you already have the point data in your grass dataset that you could export to GDAL. But I also suspect you just do all you need to in grass itself.
> > Tyler
> > On 2013-01-29, at 11:04 AM, Murat BEYHAN wrote:
>> > Dear All,
>> > Is it possible to obtain dem grid data from shapefile using gdal or ogr.
>> > info about shape file as follows
>> > murat at murat:~/maps$ ogrinfo -so -al e34c3_n.shp
>> > INFO: Open of `e34c3_n.shp'
>> > using driver `ESRI Shapefile' successful.
>> > Layer name: e34c3_n
>> > Geometry: Line String
>> > Feature Count: 4047
>> > Layer SRS WKT:
>> > (unknown)
>> > UserId: Real (11.0)
>> > FNODE_: Real (11.0)
>> > TNODE_: Real (11.0)
>> > LPOLY_: Real (11.0)
>> > RPOLY_: Real (11.0)
>> > LENGTH: Real (18.5)
>> > CVRGE34C3#: Integer (5.0)
>> > CVRGE34C3-: Integer (5.0)
>> > DETAY: String (12.0)
>> > SEMBOL: Integer (3.0)
>> > YUKSEKLIK: Real (12.3)
>> > I have installed and use grass, GMT and qgis, but I'm not good at GIS. My
>> > purpose is to obtain slope map of topographic data.
>> > any suggestion appreciated.
>> > Regards
>> > Murat
>> > This message has been scanned for viruses and
>> > dangerous content by MailScanner, and is
>> > believed to be clean.
>> > _______________________________________________
>> > gdal-dev mailing list
>> > gdal-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > Tyler Mitchell
> > Engineering Director
> > Actian Corporation
> > MOBILE 250-303-1831
> > SKYPE spatialguru
> > www.actian.com
> Murat Beyhan
> Jeofizik Yük. Müh.
> T.C.
> BAŞBAKANLIK
> Afet ve Acil Durum Yönetimi Başkanlığı
> Deprem Dairesi Başkanlığı
> Eskişehir Yolu 12. Km. Lodumlu/Ankara
> Tel:+90 (312) 2872680-1550
> <map.jpg>
Tyler Mitchell
Actian Corporation
MOBILE 250-303-1831
SKYPE spatialguru
www.actian.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130129/4b6324b8/attachment-0001.html>
