[gdal-dev] Any more GDAL WMS examples?
Carl Godkin
cgodkin at gmail.com
Thu Jan 31 06:41:43 PST 2013
Hi again,
I am still trying to come up to speed on WMS using GDAL 1.9.2 and am
interested in some examples beyond what are
posted at the bottom of http://www.gdal.org/frmt_wms.html .
I can run the various gdal_translate examples and some of them even work.
(All of them need to be adjusted since the XML file name printed in the
examples actually has "frmt_wms_" prepended, by the way.)
However, I can't get anything BUT those few examples to work. For example,
the metacarta example says this:
gdal_translate -of PNG -outsize 500 250 metacarta_wmsc.xml
However, I would like to specify a smaller area than the entire world. The
provided XML file specifies the whole world:
<GDAL_WMS>
<Service name="WMS">
<Version>1</Version>
<ServerUrl>http://labs.metacarta.com/wms-c/Basic.py?</ServerUrl>
<Layers>basic</Layers>
</Service>
<DataWindow>
<UpperLeftX>-180.0</UpperLeftX>
<UpperLeftY>90.0</UpperLeftY>
<LowerRightX>180.0</LowerRightX>
<LowerRightY>-90.0</LowerRightY>
<TileLevel>19</TileLevel>
<TileCountX>2</TileCountX>
<TileCountY>1</TileCountY>
</DataWindow>
<Projection>EPSG:4326</Projection>
<BlockSizeX>256</BlockSizeX>
<BlockSizeY>256</BlockSizeY>
<BandsCount>3</BandsCount>
</GDAL_WMS>
Merely changing the UpperLeft/LowerRight values in the DataWindow section
does not work, and I think it's because the server only serves data at
specific multiples of 180/256 = 0.703125 step sizes (or something like
that).
For example, I tried to specify the window 24 to 25 degrees E and 60 to 61
degrees N which makes a request to the server like this:
http://labs.metacarta.com/wms-c/Basic.py?service=WMS&request=GetMap&version=1&layers=basic&styles=&srs=EPSG:4326&format=image/jpeg&width=256&height=256&bbox=24,60,25,61
If I paste that URL into my browser, I get this reply:
An error occurred: can't find resolution index for 0.003906. Available
resolutions are:
[0.703125, 0.3515625, 0.17578125, 0.087890625, 0.0439453125,
0.02197265625, 0.010986328125, 0.0054931640625, 0.00274658203125,
0.001373291015625, 0.0006866455078125, 0.00034332275390625,
0.000171661376953125, 8.58306884765625e-05, 4.291534423828125e-05,
2.1457672119140625e-05, 1.0728836059570312e-05,
5.3644180297851562e-06, 2.6822090148925781e-06,
1.3411045074462891e-06]
I have a feeling that I'm making this a lot harder than it should be.
Is there some bit of conditioning code somewhere that I'm overlooking?
Can someone fashion an XML GDAL_WMS request that will retrieve a 1000
x 1000 image from the lat/lon range above?
Thank you very much for any enlightenment,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130131/ab71251d/attachment.html>
